Abbott Martin
My favorite "farts" are the Pagani Huayra and Cinque. Sound like a 9mm going off.
My shifts are a tiny bit sloppy between gears on 3.1 at WOT, most likely due to the huge TQ figures the next gear goes into. Will the DSG tune help make the gear changes more solid?
Anyone interested in videos? I took a few last night of the tachometer in various modes.
APR mentioned they don't use the OEM method of rev matching.
Added more vids.
@2013R - In the last two videos, you'll notice how the TCU holds gears longer in 1-3 gears.
its hard to tell, but i think your D mode def revs a bit higher than mine. we can't really compare though, because "pedal position" and "load" is all relative. and mine also takes too much pedal to force a downshift, i have to go really deep.
We don't change rev matching. It's the same.
The ECU DOES lock out downshifting in some situations on some models. This is removed till a little before redline.
There's still a little fart, but it's reduced. We use a different mechanism to rev-match than the factory. That's part of why our shifts are crispy, but it does cut down on the fart a bit.
Cool, no problem. Very hard to get the camera still on the tach while driving, especially in landscape mode.
All of these videos are from my commute home. Didn't really get on it too much as there wasn't much room for it. But daily driving is where you'll notice the tune the most, not WOT.
D mode:
Note: Notice how when it makes the gear change, the RPMs drop an extra ~100rpm to its final place before increasing? APR mentioned changing the way they rev match, just wondering if this is something that will get fixed in an update.
S mode:
Longer vid with a mix of D & S modes:
D/M Modes, moderate quick takeoff:
Note: Not sure what that rattle is at 45s in. I only noticed it on video. Weird.
D Mode, another moderate quick takeoff:
