Old 09-28-2017, 09:18 AM   #1
John_R_C
Newbie
Drives: 2017n GTI Premium
Steering Column Unlock to Dolly Tow
I thought my 2107 GTI didn't have a steering column lock; however, I was wrong . I need to have it unlocked to dolly tow behind my class C RV. I tried leaving the ignition on and ran into various error codes as well as the constant beeping.
Can the column lock be always unlocked via scan tool or by removing a relay or by removing something in the column to effect this? Any help is appreciated
Thanks,
John C
John_R_C is offline   Reply With Quote
Old 09-28-2017, 09:39 AM   #2
vracerw
Drives: 2012 beetle
im assuming you are towing four down and not with a dolly
vracerw is offline   Reply With Quote
Old 09-28-2017, 09:54 AM   #3
Formula 2 Driver
zrickety's Avatar
You'll need the key in...I'm not sure there is a way around that. I would disconnect the battery and reconnect it when you get to your destination. There will be initial error lights that should go out when you drive the car.
Old 09-28-2017, 07:45 PM   #4
Blakcard
FIA GT Newbie
Blakcard's Avatar
https://www.rv.net/forum/index.cfm/f...d/28959139.cfm
by the time you've read this, I'd have already done.....this > Mostly stock, APR stage 1 2.4 file, Stoptech rotors, GTS G707 rims, GFB DV
Old 09-29-2017, 11:17 AM   #5
relic1
relic1's Avatar
Drives: '12 6sp GTI
best advice from that thread.... "It might have been easier just to add a 12V charge line than to mess with your ignition/steering lock."
I have a manual key so I do not know for sure, but on other manufacturers simply pressing the start/stop button without pressing the brake gets you into what I would call an accessory mode (I know that part works on VW), it also unlocks the wheel. (I do not now if it unlocks the wheel for VW, it does on the two keyless cars I have access to)
If your thinking about cutting off the pin, why not wire in a switch to the solenoid so you can manually operate it in parallel to the standard operation. Yes it will set a code, but clear the codes when you get there, much less invasive that cutting it off IMO.
relic1 is offline   Reply With Quote
Old 09-29-2017, 09:51 AM   #6
John_R_C
Newbie
I should have been clearer. My GTI is a MK VII with the push button start, thus no key. I've already got the dolly as I saw a New Beetle being towed that way, but I don't know the year. If I had a key setup, I could leave in the accessory position to unlock the column (maybe?). Cutting off the pin may be the most efficient solution.
Anyone else care to chime in?
John C
Old 09-29-2017, 07:58 PM   #7
Blakcard
FIA GT Newbie
Blakcard's Avatar
You have asked and we've responded. Lots of choices, some will cost money some will have you clearly mess with the components of the car or you can just press the start button leave keys in, crack a window just in case it does lock or vag com that feature out and get rolling...
Whatcha gonna do??
Old 10-06-2017, 01:35 PM   #8
relic1
relic1's Avatar
Drives: '12 6sp GTI
one other thought I had on this.... you may be able to use transport mode to conserve battery power.
http://www.ross-tech.com/vcds/tour/transport-mode.php
lock doors and use the mechanical key to open the doors when you want access again.
Old 10-06-2017, 04:14 PM   #9
Blakcard
FIA GT Newbie
Blakcard's Avatar
good find!
Old 10-06-2017, 10:31 PM   #10
uglybastard
Formula 5000 Champion
uglybastard's Avatar
Drives: VW Mk6 CSG GTI 2D 6MT; Jeep WJ
2107? i must see this futuristic car!
..246.............. Insta
Old 10-07-2017, 12:16 AM   #11
Blakcard
FIA GT Newbie
Blakcard's Avatar
Old 10-07-2017, 10:07 PM   #12
whitewolf33
whitewolf33's Avatar
Drives: 2013 CW Wolfsburg
Could have got the model that hovers and this whole issue would have been avoided
Revo Stage 2 // ARM Catted DP // Neuspeed P Flo // DG Springs // Depo LED Tails // OEM Lip // 35% Tint // DeAutoLED's // Rokblokz // VAG
whitewolf33 is offline   Reply With Quote
