Old 06-28-2013, 06:07 AM   #71
elcroato
Drives: 2010 VW GTI, 2000 Skoda Octavia1.8T
Yea, I understand now. Is the crankshaft side of the timing sprocket keyed too? Based on that picture it doesn't look like it.
elcroato is offline   Reply With Quote
Old 07-05-2013, 06:03 AM   #72
elcroato
So I just found out that the chain sprocket is keyed on the crankshaft side too. Since it was bolted down in the wrong position could it have caused irreperable damage to the spur gear drive on the crankshaft? (See the picture above)
Old 07-15-2013, 08:56 AM   #73
elcroato
The job was done, but I'm now getting the following DTC upon cold startup:
001322 - Camshaft Adj. Bank 1 Intake
P052A - 000 - Cold-Start Timing not Reached
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 102038 km
Time Indication: 0
Date: 2106.14.09
Time: 07:36:42
Freeze Frame:
RPM: 1001 /min
Load: 40.0 %
Speed: 0.0 km/h
Temperature: 40.0C
Temperature: 31.0C
Absolute Pres.: 980.0 mbar
Voltage: 13.843 V
Readiness: 0010 0101
The engine also misfires like crazy and dies unless I keep on the throttle. Once the warm up phase is over it runs like a champ and no DTC's are produced.
Old 07-16-2013, 04:04 PM   #74
elcroato
I logged the camshaft timing sensor and the results were interesting. At one point the timing was advanced all the way to -36.5 while the ECU was requesting something around 28. During this stage the engine had misfires galore. Eventually, once the idle stabilized the actual value returned to what was requested.
https://www.dropbox.com/s/dmvxk41njy...mtiminglog.jpg
Does anyone know how to change the actuator valve? Is it easy?
Old 07-27-2013, 04:38 PM   #75
SoCalMK6GTI
Rally Car Champion
Drives: 2010 MKVI DBM
So how many people have actually completed this DIY?
SoCalMK6GTI is offline   Reply With Quote
Old 07-27-2013, 10:12 PM   #76
dave80
FIA GT Champion
dave80's Avatar
Drives: vw
i did without any problems.
dave80 is offline   Reply With Quote
Old 07-28-2013, 08:41 AM   #77
Formula 2 Driver
zrickety's Avatar
Nice. Is that the bolt spacer tool from Snap-on?
Old 07-29-2013, 04:28 PM   #78
elcroato
Nice job Dave80, and here is what happens if you screw up and the sprocket moves:
Old 08-09-2013, 03:02 PM   #79
hotshot100
Touring Car Champion
Drives: Gti Mk6
thanks for the DIY Ive done this replacement last weekend and everything go well. I recomand to order the 2 special tools from snapon its really help
K04 Club Member #79
Mart Mk6 Build Thread
hotshot100 is offline   Reply With Quote
Old 08-15-2013, 10:17 PM   #80
funkymcbain
Drives: 2010 MKVI GTI
What 2 special tools are you talking about? I only see the one counter hold tool.
My car sounds like that when she starts up I always wondered if that was normal, second owner of this thing. I think I'll ask the guy at the dealer if his 2013 sounds the same and if not looks like this is in my future.
Is there a reset procedure for the engine mounts?
funkymcbain is offline   Reply With Quote
Old 10-08-2013, 07:16 PM   #81
Formula 2 Driver
zrickety's Avatar
You should just mark your mounts and bolts with a paint pen, should go back fine.
The 2 special tools for this are the counter tool T10355 and the 'thrust piece' T10368. Snap on is only place I've seen the spacer, got my counter tool from Neuspeed for about $80.
I'm going to tackle this tomorrow, wish me luck.
Edit- this is another link for the most of the job:
http://volkswagen.workshop-manuals.c...ex.php?id=4237
Old 12-02-2013, 02:04 AM   #82
xHeartcoreboyx
Formula 1 Driver
xHeartcoreboyx's Avatar
Drives: '10 CW 2DR GTI DSG
Hi,
Where do we get these two tools from? http://vw.snapon.com/ is good enough?
Does the HStuning kit have all that we need?
I noticed that they don't include replacement bolts for the cover, they aren't needed?
Based on this, they are:
Originally Posted by dave80 View Post
TENSIONER [Part#: 06K109467K] $53.44
BOLT cover bolts x15 [Part#: N91096702] $0.38
SCREW crank center bolt x1 [Part#: WHT001760] $2.68
SEALANT [Part#: D174003A2] $23.79
TIMINGCASE cover [Part#: 06H109210Q] $106.14
^ But, he also doesn't mention the engine mount bolts that HStuning kit includes.
SOLD -> MK7 R
xHeartcoreboyx is offline   Reply With Quote
Old 12-02-2013, 11:39 AM   #83
Formula 2 Driver
zrickety's Avatar
The kit has everything, but you're right the cover bolts get reused. Snap on is good for the tools, but they will tell you to find a local snap on guy. I sent you a PM.
Old 12-03-2013, 12:29 PM   #84
xHeartcoreboyx
Formula 1 Driver
^Thank you!
Ordered:
1. Sealant: D174003A2 (x1)
2. CRANK BOLT: WHT001760 (X1)
3. CHAIN COVER: 06H109210Q (X1)
4. COVER SCREWS: N91096702 (X15)
5. TENSIONER: 06K109467K (X1)
6. N10552402 (X2) MOUNTING
7. N90596906 (X2) MOUNTING
8. N91029602 (X1) MOUNTING W/ STUD
9. N10701501 (X3) MOUNTING
+ both VW tools
VW manual: http://volkswagen.workshop-manuals.c...ex.php?id=6032
SOLD -> MK7 R
