JETTALINE
VW GTI MKVI Forum / VW Golf MKVI Forum / VW Golf R Forum / VW GTI Forum - Golfmk6.com
Go Back   VW GTI MKVI Forum / VW Golf MKVI Forum / VW Golf R Forum / VW GTI Forum - Golfmk6.com > Technical Topics > Wheels / Tires / Suspension / Brakes / Chassis. Sponsored by The Tire Rack
Thread Tools Display Modes
Old 11-17-2009, 05:29 AM   #1
fabiocaseiro86
Junior Member
Drives: VW GOLF V
Diference between GTI and GTD
Hello!
Can somebody tell me the diference between GOLF GTI and GOLF GTD?
they have the same chassis?
Suspension are diferent whith both DCC system?
thanks
fabiocaseiro86 is offline   Reply With Quote
Old 12-23-2009, 08:26 PM   #2
Been Dubbed a V DUB Nut
Member
Drives: GTI MK6
Originally Posted by fabiocaseiro86 View Post
Hello!
thanks
Hi there . The GTI and GTD are 100% the same as chassis and suspension . Only differents are one being petrol and other being diesel
Been Dubbed a V DUB Nut is offline   Reply With Quote
Old 12-23-2009, 10:24 PM   #3
Woofie2
Senior Member
Woofie2's Avatar
Drives: 2010 Golf TDI
I think the front suspension on the GTD is a stiffer spring, to handle the extra motor weight. Other than that they are the same beast with a different heart.
Woofie2 is offline   Reply With Quote
Old 12-24-2009, 04:26 AM   #4
kurtje
Member
Drives: VW Golf VI GTI
hmmm don't think the suspension is the same...
I think the GTD just has the sport suspension and the GTI has the GTI suspension!
In a lot of tests the biggest - is that the GTD doesn't has the GTI suspension for handling...
kurtje is offline   Reply With Quote
Old 12-24-2009, 05:23 AM   #5
dice
Junior Member
Drives: VW Golf GTD MK6
The GTD and the GTI are the same chassis and suspension. The extra weight of the GTD is only 58 kg.
dice is offline   Reply With Quote
Old 12-24-2009, 08:59 AM   #6
bubuski
El Moderator
bubuski's Avatar
Drives: MK6 GTI 5-door TR
I do not think they are thesame.
VW uk's website comparison lists the base suspension as:
GTD - "Sports suspension, lowered by approx. 15 mm"
GTI - "Sports suspension, lowered by approx. 22mm front; 15 mm rear"
DCC has three settings of comfort, normal and firm. the normal is equivalent to the base suspension above, DCC adjusts only the dampening of the shock...so I concor that the suspension is different.
Mk6 Golf GTI 5-door | DSG | Tornado Red | RNS 510 | Dynaudio | Top sport black leather | Climatronic | 18" Huffs | 16" VW Biolines(Winter) | Golf R LED Tails | 9W3 | OEM front Valance
bubuski is offline   Reply With Quote
Old 12-24-2009, 10:00 AM   #7
Whafrodamus
Senior Member
Drives: 2010 GTI 6 MT- Black
Send a message via AIM to Whafrodamus
The GTD likes different juice.
Whafrodamus is offline   Reply With Quote
Thread Tools
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
