Just to let everyone know, Uni has came out with a update to their already very good DSG flash. This new update absolutely makes the car fun to drive and keeps normal driving (light throttle) close to stock type shifting.
The changes to the original program are: (copied from a email I received from UNI)
D Mode
In D Mode, if you let off the throttle in 4th gear, the DSG will not downshift until it reached 1350rpm, then downshifts to 3rd gear very smoothly (RPMs rise to match). You keep rolling in 3rd gear and at 1350rpm, it will shift into Neutral (showing D2 on MFD in cluster). When you hit the brakes in 3rd gear, it will then downshift into second, and then first when you come to a stop. D mode will also upshift every gear at 2400 RPM for drivability and fuel economy
S Mode
In S Mode, anytime you let off the gas OR push the brakes, the DSG will downshift into the next lowest gear smoothly and rev match the next lowest gear.
M Mode
Manual Mode - self explanatory. Makes all gears manual.
I loved the changes in the first flash, now that this update is out it's just that much better!!!
