Old 03-28-2014, 01:17 PM   #225
f00kie
Drives: TBD
I have the Unitronic relocation kit. Recently, I had an APR intercooler installed, which is quite a bit thicker than the stock intercooler. As a result, and due to the positioning of the DV relocation, my air charge pipe lays flat against the radiator fan. I haven't seen that radiator fan spin: I think it is dead. Also, my air charge pipe has indentation marks from the fan spinning against it.
Anybody else have this issue? I am in the process of getting the Neuspeed air charge pipe to see if it would work better, but I'm not quite sure.
f00kie is offline   Reply With Quote
Old 03-28-2014, 03:05 PM   #226
Mustache rash
Formula 5000 Champion
Mustache rash's Avatar
Drives: 2011 K04 GTI 6mt
Which throttle body pipe do you have, stock?
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Mustache rash is offline   Reply With Quote
Old 03-28-2014, 03:09 PM   #227
f00kie
Drives: TBD
Currently stock. Moving to this over the weekend to hopefully alleviate issues: http://www.neuspeed.com/480268-hi-fl...-amplifer.html
Old 04-04-2014, 10:13 PM   #228
ChrisChen1990
FIA World Rally Car Newbie
ChrisChen1990's Avatar
Drives: 11' GTI 2-door
Does anybody know if I need to have recirculating after I relocate the diverter valve with the HKS SSQV?
APR Stage 2, SPM street downpipe, Neuspeed cat-back, K&N air intake,Forgemotorsport quick shifter Koni coilovers, H&R 26mm FSB, 22mm RSB, StopTech brake lines, EBC red stuff brake pads, O.Z Opera II, CTS turbo oil catch can, Unibrace UB, R8 coil packs, P3 car gauge, BSH throttle body pipe, Synapse DV, RSR Clutch
ChrisChen1990 is offline   Reply With Quote
Old 05-26-2014, 06:57 PM   #229
Mustache rash
I would. It will throw your trims off.
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
