The Tire Rack
Old 05-04-2015, 10:23 AM   #1
ForzaGTI
ForzaGTI's Avatar
Drives: MK6 2010 GTI CSG 6 SPEED
Advice on my suspension part list - Google Sheet
Hi folks,
I compiled together a Google sheet, that lists all the parts and parts numbers along with prices for what I need to upgraded the Front Suspensions.
I want advice/help/blessing on row 9, Upgraded Front Strut Mount Kit.. Like are the parts under 9 (9.1 to.9.10..etc) the correct upgraded replacement for the MK6 GTI?
Getting mix inputs where some say the Audi bolts won't work etc...
I wish theBruce can comment on this, but I can't tag him on this post.
Thank you for your assitance on this.
PS: Comments are enabled on the sheet. Edits are disabled.
2010 GTI CSG 6MT | APR K04 | Carbonio | VWR Springs | GFB DV+ | APR FSB-RSB | VW Subframe Mount | UNIBRACE XB | EUROJET GEN 2 TBE | Neuspeed Rse52 18x8 ET45
ForzaGTI is offline   Reply With Quote
Old 05-04-2015, 01:49 PM   #2
Formula 2 Driver
zrickety's Avatar
This is a great idea. I ordered most of this stuff recently, I can double check when I get home.
Old 05-04-2015, 03:20 PM   #3
GreasyGinzo
Formula 2 Driver
GreasyGinzo's Avatar
Drives: 2011 GTX2867 GTi Autobahn 6mt
I have and like the 034 Motorsport strut mounts better than the TT mounts
People tend to make a huge deal out of replacing every single nut, bolt and washer when removing them. I didn't replace any bolts when my coilovers where installed, nor when I installed my ALK and my subframe has been out twice without replacing any bolts and I don't have subframe clunks and my world hasn't ended and my car hasn't blown up.
Build Thread / Life Story
GreasyGinzo is offline   Reply With Quote
Old 05-04-2015, 05:43 PM   #4
rawag77
Touring Car Champion
Drives: 2013 GTI Autobahn
I just did springs/struts/LCA's and used a similar spreadsheet. Here's a quick screen cap. Ordered all from Deutscheautoparts.com. Not sure if it's all absolutely needed.
Also I didn't think the H&R sways needed to be greased since they have teflon-lined bushings, no?
Click image for larger version
rawag77 is offline   Reply With Quote
Old 05-05-2015, 06:33 AM   #5
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
They don't
2017 Passat VR6
2017 Passat R-line
Old 05-06-2015, 12:18 AM   #6
aricolton
Drives: 2 door 2011 GTI dsg
I have bilstein b8 shocks, dg Springs, Hotchkiss front and rear sway bars, ecs tuning upgraded strut mount kit, Tyrol sport dead set subframe collars, white line endlinks, and hankook rs3 tires. I use the car for daily driving, autocross, and the occasional track day. I couldn't be happier with the way the car handles.
aricolton is offline   Reply With Quote
Old 07-22-2015, 12:52 PM   #7
ForzaGTI
ForzaGTI's Avatar
rawag77, so helpful thank you buddy!
Nope, they don't need greasing at all.
