Old 05-31-2016, 02:45 PM   #29
RichBGTI
Oval Newbie
RichBGTI's Avatar
Drives: 2011 Candy White GTI
DIY K04 Install Notes/Helpful Tips
So brute force prevailed. Removed what bolts I could from the heatshield and then fatigued the shield until it broke off. I'll deal with the bolt once the turbo is off and can access more freely and replace heatshield. Tried a torx and bigger hex hammered in to no success.
Got a screw extraction kit coming tomorrow so will give that a pop.
Got the 5 manifold bolts loosened and with the heat shield out the way. Can see and with relative ease get to the downpipe studs with a socket, so things are looking up!
2011 GTI | Milltek TBE | APR Carbonio | F23T | TTRS Brembo | ST XTA Coilovers | do88 IC | AEM WMI
Instagram: @richbrdfld
RichBGTI is offline   Reply With Quote
Old 06-02-2016, 11:36 AM   #30
lilfleck
Moderator
Drives: '11 GTI Autobahn, DSG
So the heatshield bolt is connected to the manifold not the head?
lilfleck is offline   Reply With Quote
Old 06-02-2016, 11:37 AM   #31
RichBGTI
Oval Newbie
RichBGTI's Avatar
No, it's in the head.
Old 06-04-2016, 09:23 PM   #32
Geryon86
FIA World Rally Car Newbie
Geryon86's Avatar
Drives: MK7 R
16' LB R | DSG | APR Stage II HT |
11' SB GTI
|DSG|APR v3.1|CTS K04|
Geryon86 is offline   Reply With Quote
Old 06-06-2016, 08:26 AM   #33
Brunkel
Formula 5000 Champion
Brunkel's Avatar
Drives: 2013 UGM GTI; 6-speed manual
Sub'd! Great write up!
Build Thread
Hi-Def Detailing
Brunkel is offline   Reply With Quote
Old 06-06-2016, 03:21 PM   #34
RichBGTI
Oval Newbie
RichBGTI's Avatar
These writeups really are invaluable!
Old 06-06-2016, 03:28 PM   #35
RichBGTI
Oval Newbie
RichBGTI's Avatar
So that plug.
Different position on TSI. It's between cylinder 3 and 4 around the same height as the pic above.
Once the the turbo was off, I was able to get the plug out. I could see what it may have been taken out at some point in the past and was already a bit rounded off which prevent the hex from fully seating. Was able to hammer in a hex and was fine. Hard to check when everything is in the way.
hammering in an XZN bit does the job too!
Old 06-06-2016, 10:58 PM   #36
Geryon86
Geryon86's Avatar
Drives: MK7 R
Originally Posted by RichBGTI View Post
So that plug.
That is a TSI and it is between cylinder 3 & 4. It's a picture of the back of the engine with a mirror.
11' SB GTI
Old 06-07-2016, 01:54 AM   #37
RichBGTI
Oval Newbie
RichBGTI's Avatar
Ha, didn't spot the mirror!
Old 06-10-2016, 09:28 PM   #38
Brunkel
Brunkel's Avatar
Are these just basic locking plyers? The eBay link you posted is down.
Build Thread
Hi-Def Detailing
Old 06-10-2016, 09:59 PM   #39
XGC75
Formula 1 Driver
XGC75's Avatar
Drives: into shit
^^ for those and the bolt holding the banjo on the fluid line to the turbo it's best to use a triple square set with some kind of hex pattern on the bit just before the socket end. What I did was to put the M(something) into the bolt, then used a 10mm crescent wrench to torque the M(something) bit.
Edit: like so:
Sincerely, XGC75
XGC75 is offline   Reply With Quote
Old 06-10-2016, 10:33 PM   #40
Brunkel
Brunkel's Avatar
Edit: like so:
Sincerely, XGC75
Nice! I have the this kit per this thread: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
so that should definitely work. What other tricks you got for this install!?
Ordered my long reach ball head hex socket set for the 6mm...
Just from reading everything I feel like when the heat shield comes off it should just rain beer from all cylinders in celebration.
EDIT. Holy crap...I see you're in SW Michigan. Where at? I'm 20 minutes from the boarder.
Build Thread
Hi-Def Detailing
Old 01-05-2018, 01:16 AM   #41
Mk6 Steve
Rally Car Newbie
Drives: 2013 Black GTI coupe DSG
lilfleck's K04 Install Notes/Tips
Additional Recommended Hardware:
Exhaust Manifold Studs (there are 5, but you don't need to replace them unless they break) - N0444115
6mm Allen Screws on Turbo Support (1x) - (not sure of PN)
6mm* (skinny) Allen Screws on Turbo Heat Shield (2x) - M8 X 1.25 (not sure of PN)
6mm* (fat) Allen Screw on Turbo Heat Shield (1x) - (not sure of PN)
Sorry to bring this thread back from the dead but I wanted to add a little info to the thread about some part numbers that will make the parts list a little more complete. Maybe the OP will add it to the original thread so future users don't suffer set backs like myself and like plenty of others in the past have as well I'm sure...
In regards to tools I don't have anything special to add other than to reiterate as stated before and make sure you follow this thread word for word. Without long ball hex sockets/allen wrenches as well as this tool kit (https://www.amazon.com/gp/product/B0...=1):happyanim:) that has a combination of long and short hex, torx and triple square this job wouldn't be pleasant by any stretch! Also instead of PBlaster I was recommended that I use this other stuff called AeroKroil. Its a little pricey but it works far better and I've been using PBlaster for 2 decades! But anyways lets get to the good stuff...
Exhaust manifold studs (attaches exhaust manifold to block) - M8 X 44 - N0145555
(1)Turbo support bracket (upper 6 mm hex bolt) - N91103701
Heat shield (has 2 different bolts, but 3 bolts need to be removed in total):
(1) 6 mm hex plug - N0160255
(2) 6 mm hex bolt - N01627801
(1)Oetiker clamp 15.7 mm - N10199201
APR V3.1, APR K04, Carbonio Stg 1+2 w/ AEM dry-flo filter, APR RSC TBE, Do88 Ic, 034 Catch Can Kit (summer), OEM pcv "AH" (winter) AWE S3 top, Neuspeed charge pipe, Rev D w/ DV+, R8 coils w/ NGK 2668, 034 motor/trans mounts, HPA 75A, TyrolSport subframe and brake stiffening kit, Unibrace UB, F+R Centric w/ StopTech Strt pads, USP SS brake lines, Depo dark cherry tails, ECS Blind Spot Mirrors, Enkei 18x8 black M52 w/ Conti DWS, Soundaktor delete, VCDS Hex-Can, P3 gauge
Mk6 Steve is offline   Reply With Quote
