Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Volkswagen GTI / Golf Topics > Mk6 vs......
Old 09-27-2016, 04:16 PM   #1
Disanto7389
Drives: 2013 cw 4 door 6 speed.
Scariest car jack in history
I'm new to this car and this forum, so hello! . I had to change my tire the other day thanks to NJ roads putting 2 nails in my tire.. what the hell is with the jack that came with these cars? It is by far the most sketchy jack I've ever seen. It doesn't even seem remotely safe to me. Do you guys trust it? Or did you pick up one?
Disanto7389 is offline   Reply With Quote
Old 09-27-2016, 04:28 PM   #2
Blakcard
FIA GT Newbie
Blakcard's Avatar
agreed....never used a jack that came with a car.........EVER.
I have a floor jack @ home and pray I make it home w/o needing to use the one in the car. I should toss it cause #weightsavings but i'll keep the killer in place just in case... and if I do have to use it once the flat comes off it goes under the car to be a safety net for me while i put the spare on.
by the time you've read this, I'd have already done.....this > Mostly stock, APR stage 1 2.4 file, Stoptech rotors, GTS G707 rims, GFB DV
Old 09-27-2016, 04:40 PM   #3
jay745
Mod Flanders
jay745's Avatar
yeah it's garbage. They call it the widowmaker for a reason.
Old 09-27-2016, 05:57 PM   #4
Disanto7389
Lol I'm glad I'm not the only one. I had to call my friend with a real jack to support it incase it slipped. The widow maker? That's not very confidence inspiring lol
Old 09-27-2016, 07:49 PM   #5
whitewolf33
whitewolf33's Avatar
Drives: 2013 CW Wolfsburg
I thought this was going to be scariest car jack(ing) in history. Im so disappointed. Not that I want to see that happen to you or anyone on here but its interesting to see or read about
Revo Stage 2 // ARM Catted DP // Neuspeed P Flo // DG Springs // Depo LED Tails // OEM Lip // 35% Tint // DeAutoLED's // Rokblokz // VAG
whitewolf33 is offline   Reply With Quote
Old 09-27-2016, 08:02 PM   #6
Disanto7389
Lol. Well let's hope that doesn't happen. Luckily for us the subaru seems to be one of the more stolen cars. Atleast from what I've heard around NJ and NY
Old 09-28-2016, 12:07 AM   #7
thewalkingdad
FIA World Rally Car Newbie
thewalkingdad's Avatar
Drives: 2013 GTI DSG
I had to use it once within the first month of buying this car and it was a scary experience. Everything turned out OK, but I was very nervous. Thankfully when I used it, I didn't have to get under the car, I just needed to put the spare on.
Stratified Cobb Stage 2 | IE Cold Air Intake | ST Coilovers | SPM Downpipe | Rev9 Intercooler| 034 Stage 2 DSG Tune, dogbone, insert, mounts & RSB
thewalkingdad is offline   Reply With Quote
Old 09-28-2016, 01:30 AM   #8
corydd
corydd's Avatar
Drives: '10 CW GTI DSG Autobahn
Yup, the widowmaker.
'10 CW DSG GTI Build Thread & Flickr * APR Stg 1 * Depo Tails * Magnaflow CBE * OEM Lip * VW Motorsports Wheels * VWR Springs * Stoptech Pads * DeAutokey LED's * 24mm H&R RSB
corydd is offline   Reply With Quote
Old 09-28-2016, 07:59 AM   #9
kern417
Formula 2 Driver
Drives: '09 Jetta
it's not so bad in a pinch but definitely wouldn't use it as my primary one. the slot fits the rail perfectly so as long as the ground is level you should be ok.
do a burnout.
kern417 is offline   Reply With Quote
Old 10-26-2016, 07:42 PM   #10
dead_catz
Rally Car Champion
Drives: car
Its all how you jack it, I practice jacking it every couple of weeks or so.. i would hate to not be able to perform when my Candy white girl needs pumped up.
dead_catz is offline   Reply With Quote
Old 10-27-2016, 06:48 PM   #11
Formula 2 Driver
zrickety's Avatar
Lol. Even on level ground I found the scissor jack is dangerous. Flat tire use only, get a real jack at home.
Old 10-29-2016, 11:11 PM   #12
visceralsoup
visceralsoup's Avatar
Drives: 2013 VW GTI (sold), 2012 Golf Arrrr
Same.
2 MOJITOS, STAT!- Thad Castle
Turbo Ranger Build
visceralsoup is offline   Reply With Quote
Old 02-08-2017, 01:15 AM   #13
Jaja3144
Drives: 10' Golf Mk6 2.5 MT
Yea, avoid the car's jack... one time I used it the jack started to slip and ended up digging into the bodywork quite badly.
Jaja3144 is offline   Reply With Quote
Old 02-10-2017, 12:09 PM   #14
ithrashmotors
ithrashmotors's Avatar
Drives: Mk6 gti
Yea that jack is just for quick flat tire fix. Any scissor jack is not safe to crawl under a car with. I don't see the one our cars came with more scary than any other scissor jack out there. Just be smart and don't get under your car with it. And if you have to for whatever reason pray to the car gods your ass crawls out lol
APR stage 1//Carbonio intake//R8 coilpacks//GFB DV+
ithrashmotors is offline   Reply With Quote
