DSG Oil Overheat
watusay
Hey guys, having a weird issue that I havent had before (unless I launched too many times).
My car is Stage2+ and has been for a while. It recently went to the dealer for its service and they changed the DSG fluid.
All is well, until I decide to launch the car. And as soon as I do that the DSG Overheat red warning comes on. Car has Unitronic DSG tune.
VCDS shows an average og 80 to 90 degrees celsius on all 3 blocks on Group 019 when the car is fully warmed up and have given it a few WOT runs. Only when I launch does the Clutch Fluid Temp shoot up to 170 celsius and as soon as I back off it takes a few seconds for it to come down to 100 degrees celsius.
Also have loaded the Stage2+ 98 tune ( was using a watered down 95tune as the fuel is bad here) since I have my WMI installed. Zero timing issues and the car feels amazing and strong
Do you think the dealer underfilled or orfilled my gearbox. Or is the torque from the stronger tune overheating the DSG? I am using the DSG tune and it has never done this before
The Fixer
Offhand it sounds underfilled. How many miles/km and have you ever changed the coolant? Possible your radiator has some bent fins or blockage that would prevent cooling?
watusay
Car has 50K KM only. Coolant has been done and no the fins etc are awesome. Only happens when I launch. I did my own DSG service 15k KM ago and did use Motul DTCF and never had a single probblem. It now does it every single time I try launch, even on a cool day, can be my first launch and all the fluid temps are ideal, I just launch, temp goes up and warning comes, I back off and in literally 10 seconds it goes back to ideal
The Fixer
I also run motul. Sounds like oem fluid is not up to the job.
watusay
The OEM fluid is quite decent, I had it before changing to Motul and was handling the launches okay.
Ive also read that over filling can cause heat issues as well...just dont know what the best way to make the car level would be in my garage, as I have no decent lift around me for about 250KM. My garage is flat
MacRadiators
Just remove oil, and then put 4.7l inside the gearbox, filling from the filter's side.
I also use motul dctf and its perfect.
