Old 02-23-2017, 08:34 PM   #1
FlowMK6
Touring Car Newbie
FlowMK6's Avatar
Drives: Golf 2.5 6speed MT
Question about engine-trans mounts
Hi all, I got a question about engine and trans mounts, I bough a pair of 034Motorsports mounts:
http://www.uspmotorsports.com/Volksw...Pair-2.5L.html
I would like to know if the trans mount is for manual 5speed or 6speed automatic (I hope it's for 5speed, otherwise I feel stupid...)
Also, I would like to know which mounts are better between 034Motorsport and BFI.
Thanks in advance, kind regards.
FlowMK6 is offline   Reply With Quote
Old 02-24-2017, 01:40 PM   #2
lacesoutvic
Drives: 2013 2.5L Golf
Just eyeballing and comparing BFI's mounts and 034's mounts, I think they should be fine for the 5-speed and tiptronic auto transmissions. I bought a set (auto trans) so we'll find out soon enough hahah.
Looks like the 6-speed/DSG mounts have an additional bolt hole, looks trident-ish. But the side bolt holes may be the same dimensions...
lacesoutvic is offline   Reply With Quote
Old 02-24-2017, 03:16 PM   #3
FlowMK6
Touring Car Newbie
FlowMK6's Avatar
I think the additional bolt hole in the middle of the BFI automatic mount is for the DSG, since 2.5 doesn't have DSG, 034Motorsport only put 3 holes, and the one in the middle is for the automatic one, I think the mount fit for both, the manual would need only 2 bolts while the automatic needs 3.
That's only a guess and I hope I'm right, otherwise I'm fucked ^^ I will tell you in a few hours once installation is done
Old 02-24-2017, 05:05 PM   #4
lacesoutvic
Definitely post back, good luck with the install!
Old 02-24-2017, 09:32 PM   #5
FlowMK6
Touring Car Newbie
FlowMK6's Avatar
Mounts are installed, the trans mount fitted on the manual transmission, engine doesn't move at all even at 7000rpm, also I don't feel any vibration, it's smooth, I love it, definitely a good purchase, I will install the dogbone and the insert once I receive it
Edit: On reverse, there is more vibration on the friction point. But seriously, comfort isn't affected.
Old 02-24-2017, 10:08 PM   #6
brobst
Formula 5000 Champion
brobst's Avatar
Drives: CSG mk6 6MT
The dogbone is what gives the good vibes
Sent from phone Tapa
K04 P&P | 325whp/325wtq | Beyond Superior Interior | Brobst's Build | Data logs
