Old 03-01-2017, 09:27 PM   #15
iceorbital
Drives: VW Golf R 2012
For those with the deka 47 or 48, can you share pics? I'm concern the oem battery is rated 72ah vs 60ah for the deka 47, and i'm concern of the 48 been to large. I have a 2012 golf r.
iceorbital is online now   Reply With Quote
Old 03-02-2017, 01:49 AM   #16
Bozz
Bozz's Avatar
Drives: 2012 R, 94 Explorer, 80 Corvette
I do not own a Deka but I can say, their 47 and 48 are shown as fitting our cars in the Deka Online Catalog. So I don't think the 48 would be too large. The Group 48 Deka AGM has a Reserve Capacity of 120 which is the Golf R spec. The Group 47's are more like 100 RC.
Bozz is offline   Reply With Quote
Old 03-02-2017, 08:20 AM   #17
TimS
Rally Car Champion
Drives: '12 Golf R
You have to leave off the insulation sleeve with the 48, but it fits the battery box fine. I'll snap a pic later this afternoon.
Old 03-02-2017, 03:47 PM   #18
bebersol
Rally Car Champion
bebersol's Avatar
Go with the DEKA group 47. The AGM battery is rated at 600cca the oem is rated at 480.
some folks on the forum are running DEKA AGM etx18's and 20's and are super happy with them, plus they drop about 50% of the battery weight.
http://www.golfmk6.com/forums/showthread.php?t=37547
Bunch O'Stuff :-)
Old 03-02-2017, 04:08 PM   #19
iceorbital
47 it is. The thing that was concerning me is the OEM varta had 72Ah, versus 60Ah for the Deka.
Old 03-02-2017, 05:07 PM   #20
B6JoeS4
B6JoeS4's Avatar
Drives: 12 CSG DSG 4D GTI
AGM is absorbed glass mat, not acid glass mat
B6JoeS4 is offline   Reply With Quote
Old 03-03-2017, 04:13 AM   #21
Bozz
Bozz's Avatar
This was my concern as well. This was discussed in the past, and the Ah rating is related to the Reserve Capacity that I mentioned earlier in this thread. I am not expert enough with batteries to know the exact relationship...
The consensus in the old discussion seemed to be that the Golf R's accessories -- like the electric coolant pump running a few minutes after the car is off - would not be enough drain to harm the battery, even with the lower RC/Ah rating.
Then again, the VW engineers spec'ed 120/72 for a reason I'm sure. We can hope they were just being cautious.
Old 03-03-2017, 06:04 PM   #22
bebersol
Rally Car Champion
bebersol's Avatar
that was a typo, thanks
Bunch O'Stuff :-)
Old 03-04-2017, 11:50 AM   #23
JetTurbo
JetTurbo's Avatar
Drives: 12 mk6 Golf R, 08 b6 Passat v6 4-mo
Arrow
I use an O'Reily's Group 48 Super Start Platinum AGM battery in my 2012 Golf R. 70 AH, 120 RC, 760 CCA.
Its length and width are pretty much exactly the same as the oe Varta.
No issues with the insulation sleeve, fits the same as oe.
The O'Reily's Group 48 battery is slightly different in height, but not enough to make any difference at all.
Battery box, insulation sleeve, and battery cover all fit without issue.
I seem to be hard on batteries.
The oe Varta battery died in about 2 years at 60k miles.
I expect an AGM battery to last longer than an oe battery.
I installed the O'Reilly battery in the Fall of 2014 and it seemed fine.
However, in Fall of 2016 (just short of 2 years, ≈50k miles),
it starting giving me trouble, forcing me to jump start.
Took it with my original receipt to the same store I bought it from to be tested.
They did not bother to test it, they just swapped it out for a new one, no questions asked.
So while it gave me some hassle what seems to be too soon,
it did not cost me anything to have it replaced.
Ultimately, even if the replacement fails just as fast,
I will end up with 4 years of use for the original $$ outlay.
4 years is what I typically expect from a battery.
anything after that is bonus too me.
As for the comments about getting by with lower rated batteries,
as long as you are in ideal conditions, should not be much of an issue.
Just keep in mind, if you deal with extreme cold, it may be an issue.
The reserve capacity rating is the time (in minutes) that a lead-acid battery at 80 F (27 C)
will continuously deliver 25 amperes before its voltage drops below 10.5 volts.
Assuming that rating is 120 minutes,
at 32 degrees F, typical capacity is reducted by 35 percent (78 min);
at zero degrees F, it is reduced by 60 percent (48 min);
and at minus 20 degrees F, it is reduced by better than 80 percent (24 min).
I occasionally have to park outside overnight
(at hotels) in Michigan and Canada in January / February.
For me, that is the least convenient time for a battery to come up short.
i.e. I am unwilling to risk any significant under-rating
so as to avoid the worse case scenario.
And with the first and the current O'Reily's Group 48 batteries,
have had no issues in those cold conditions.
2012 2dr RB Golf R
JetTurbo is offline   Reply With Quote
Old 03-12-2017, 01:46 PM   #24
Bozz
Bozz's Avatar
Your O'Reilly's battery is also made by East Penn / Deka...another plus
Thanks for posting about it
Old 05-30-2017, 10:51 PM   #25
B6JoeS4
B6JoeS4's Avatar
Bumping this. The group 48 AGM batteries all seem to be the exact same one made by East Penn. They all have failure issues so I would avoid them if you can. Here is the Duralast version they tested....they also tested the DieHard. Same result
http://www.consumerreports.org/cro/n...test/index.htm
Looks like JetTurbo's experience lines up with the test results. The East Penn 48 AGM battery is no good.
I ended up going with a Costco Interstate group 48. $110 and it has 42 month free replacement, hard to beat that.
APR Stg2 v2.4 || AWE intake || Cobb TBE || ARM FMIC || 034 Mounts || Depo LED's || Podi || Alzor Peelers || Eibach ProKit || R32 Brakes
Old 05-31-2017, 07:20 AM   #26
TimS
Rally Car Champion
Drives: '12 Golf R
The Die Hard and Duralast brands are manufactured by Johnson Controls. There's nothing wrong with East Penn batteries.
