VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum -
Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - > Volkswagen GTI / Golf Topics > VW Golf R Forum
Old 06-03-2017, 08:00 PM   #1
Golf mk6 r apr stage 2+
I've just got my car back from basically getting APR stage 2+.
The power gains are great and I only have one concern,has anyone experienced slight vibrations from around the downpipe when accelerating in the lower range of gears 3,4,5 etc and applying power in low rev
Sent from my iPhone using Tapatalk is offline   Reply With Quote
Old 06-04-2017, 08:10 PM   #2
FIA GT Champion
Squashdaddy's Avatar
Drives: 6MT 2011 GTI
If it's an un resonated down pipe, you may get vibration resonance.
APR Stage 2 ECU - APR Carbonio Stage 1+2 - 42 Draft Designs Catted/Resonated Downpipe - Neuspeed Charge Pipe and Turbo Outlet Pipe - GFB DV+ - Fluidampr Crank Pully - HS Tuning RSR clutch -H&R 24mm rear swaybar - Unibrace UB - HPA Red Puck -Neuspeed Rse12 Hyperblack
Squashdaddy is offline   Reply With Quote
Old 06-05-2017, 07:33 PM   #3
Schyzo's Avatar
Is the dp rubbing on the heat shield underneath. I know mine was touching upon installation so I bent the sheild a bit and no more touching.
Sent from my XT1563 using Tapatalk
Schyzo is offline   Reply With Quote
Old 06-05-2017, 07:56 PM   #4
Touring Car Champion
Drives: MK6 Golf R
Running stage 2+
Initially was awesome didnt notice anything.
I have a straight downpipe no resonator/cat.
Noticed vibrations directly under shifter so checked under the car and noticed from all the vibrations that my bolts that hold up the middle section of the driveshaft started to come loose allowing enough play to hid my midpipe section once in a blue. Check under the car regularly. Yo might start getting sounds going to stage 2 with the mods and or work performed. Double check everything done to the car too
Mk6 Golf R | APR Stage 2+
joeyfrost is offline   Reply With Quote
