Old 05-17-2016, 03:42 PM   #71
PlaidDad
Oval Champion
Drives: Shadow Blue GTI DSG 4 dr, 2011
First time for me today, had been driving at low speed suburban driving for around 20 min, was do about 30 with mild throttle. Low Oil Pressure do not exceed 4000 RPM message came on and off several times.
Pulled over, checked oil, level fine. Car sat for 20 minutes, restarted and no repeat alarms. Have about 79.5k miles on it...
This stuff will drive you nuts.
2011 Shadow Blue 4dr DSG. APR Stage 1 ECU & TCU tunes , Carbonio Stage 2, Enkei PF01, Pilot Sport A/S3s, DG springs, Koni STR.T, H&R 26/24 bars, Tyrolsport brake kit, Powergrid F end-links, Soundaktor delete, Hella Supertones
PlaidDad is offline   Reply With Quote
Old 08-03-2016, 11:46 AM   #72
rasetsu
Rally Car Newbie
Drives: 2011 GTI, 2014 RS 5, 2005 STi
Update: over a year later and light came on again under the same slow speed circumstances. Chimed, flashed, went away. The orange RPM warning flashed two more times as I went up an on ramp and then no more.
rasetsu is offline   Reply With Quote
Old 09-03-2017, 06:15 PM   #73
Mk6Daddy
Touring Car Champion
Drives: 2011 Autobahn
Bump. Happened to me last night. Bumper to bumper traffic, hot night, 4K rpm warning came on. Got home, oil level ok. Started up today, no issue. 2011, about 84k miles. Has anyone come up with a solution?
Mk6Daddy is offline   Reply With Quote
Old 09-06-2017, 03:40 PM   #74
vwgti2.0t
Formula 3000 Champion
Drives: 2011 CW GTI
I changed the oil pump, main and rod bearings, cam bearing bridge, screens, etc. Basically everything and it was still happening. Finally thought about it a little bit and the only thing left was the balance shafts. Took it apart (again) and they were the culprit. Hasn't been back in almost a year, and it was happening weekly before that.
vwgti2.0t is offline   Reply With Quote
