Old 09-10-2017, 06:10 PM   #1
TaHoE
Drives: 2014 GTI
Newbie Here
Hey folks!
Just picked up this new (to me) '14 GTI Wolfsburg. I'm new to VW and absolutely love the way she drives. She's currently stock. I am up for some lights mods, but nothing to outrageous. Was curious if you guys had any suggestions on where to start. Appreciate all your help!
TaHoE is offline   Reply With Quote
Old 09-10-2017, 06:53 PM   #2
1ashchuckton
1ashchuckton's Avatar
Drives: 2013 GTI Carbon Steel Grey DSG
Welcome nice GTI.
Old 09-11-2017, 07:44 AM   #3
GreyGti1990
Drives: 2011 Gti 4-door
Welcome! Are you looking for performance mods?
2011 4-door CSG 6-speed GTi - Sigma Six, Boost gauge, AWE TOP/CTS Throttle, APR Carbonio, Revo 2, GFB DV+,SB st3 Daily(485ft lbs), VWR FSB, DG Springs, WALK, Collar Kit, Fluidampr, APR downpipe, 225/45/17 PSS, Sparco Assetto Gara, Stoptech slotted rotors/pads, Uni Intercooler, BFI Knob, USP SS lines, ATE fluid, Beluga Cat-back, LED Tails, New Tensioner.
Soon to Come: Tints, R Bumper, Headlights, Pendulum Mount, Rear sway
GreyGti1990 is offline   Reply With Quote
Old 09-11-2017, 10:23 AM   #4
SyDiko
FIA GT Newbie
Drives: 2012 GTI
Welcome!
Most folks would suggest going Stage 1. However, I'm not most, and I'd recommend starting with some Coilovers! A much lower ride height really brings out the sportiness of the GTI.
SyDiko is offline   Reply With Quote
Old 09-11-2017, 10:59 AM   #5
Mk6 Steve
Rally Car Newbie
Drives: 2013 Black GTI coupe DSG
Stage 1, R8 coil packs and a DV+ should be a good start.
APR V3.1, APR K04, Carbonio Stg 1 + 2 w/ AEM dry-flo filter, APR RSC TBE, Do88 Ic, 034 Catch Can Kit (summer), OEM pcv "AH" (winter) AWE S3 top, Neuspeed charge pipe, Rev D, R8 coils w/ NGK 2668, 034 motor/trans mounts, HPA 75A, TyrolSport subframe and brake stiffening kit, Unibrace UB, F+R Centric w/ StopTech Strt pads, USP SS brake lines, Depo dark cherry tails, ECS Blind Spot Mirrors, Enkei 18x8 black M52 w/ Conti DWS, Soundaktor delete, VCDS Hex-Can, P3 gauge
Mk6 Steve is offline   Reply With Quote
Old 09-11-2017, 11:39 AM   #6
TaHoE
Drives: 2014 GTI
Hi! Thank you! I am certainly open to that!
Old 09-11-2017, 01:01 PM   #7
GreyGti1990
Stage 1 tune for APR/Unitronic/Revo/Cobb would be a good start. BUT! be warned that usually when going stage 1 software your stock coilpacks tend to go (replace with audi R8, red top, coil packs) and if you are a manual 6-speed (not DSG) driver then your clutch may begin to slip. Its hit or miss with the clutch but when I went stage 1... a week later mine slipped. Others have gone 40k+ miles without it slipping. If you are a manual owner and want more performance... start to save for a new clutch; you will need it. Could grab a cold air intake as well but it is not required for stage 1 tune.
Your is a 2014 so your timing chain tensioner is probably the new revision which is good. The intake manifolds tend to break and are covered under warranty till 120k miles I believe. Water pump also tends to go, mine was covered by a recall and replaced free of charge.
Be on the lookout for a carbon cleaning, not sure how many miles you have but direct injection engines tends to need a good carbon cleaning on the intake valves after a lot of miles.
Old 09-11-2017, 01:58 PM   #8
ithrashmotors
FIA World Rally Car Newbie
ithrashmotors's Avatar
Drives: Mk6 gti
+1
APR stage 1//Carbonio intake//R8 coilpacks//GFB DV+
ithrashmotors is offline   Reply With Quote
Old 09-11-2017, 09:30 PM   #9
Formula 2 Driver
zrickety's Avatar
Stage 1 and you'll be really happy. Even if the clutch starts to slip, just ease off the gas it will last. These cars are really some of the best out there.
Old 09-12-2017, 12:23 AM   #10
whitewolf33
whitewolf33's Avatar
Drives: 2013 CW Wolfsburg
Everyones famous words lol. You definitly need at least stage 1. Dont let anyone tell you otherwise. Get some R8 red top coil packs as a percaution. Personally, I dont think the DV+ is necessary, especially on a 2014 which will have the piston style dv. Whether it be springs or coils, Id lower the car a little. LED tail lights are also a must have.
Revo Stage 2 // ARM Catted DP // Neuspeed P Flo // DG Springs // Depo LED Tails // OEM Lip // 35% Tint // DeAutoLED's // Rokblokz // VAG
whitewolf33 is offline   Reply With Quote
Old 09-13-2017, 12:54 AM   #11
realcyberbob
realcyberbob's Avatar
Drives: 2011 GTI
Send a message via AIM to realcyberbob
Best light mod is k04 or larger.
2011 CW GTI 6-Speed: APR Stage II, APR Carbonio Intake, Clutch Masters FX350 Clutch Kit, 42nd Draft Designs Downpipe, Magnaflow Catback Exhaust, Forge Twintercooler, BFG DV+, Dieselgeek Short Shifter, ECS Dogbone Mount Insert, StopTech Pads & Slotted Rotors, Tyrolsport Brake Stiffening Kit, Golf R LED Tail Lights, CiM Vent Boost Gauge, RNS-510 Navigation, Uber-Stealth Box & 10" Pioneer Sub, Alpine MRP-M500 Amp, 25th Ann. GTI Golfball Shift Knob, Modshack Low Profile Engine Bay Trim, Hankook V12
realcyberbob is offline   Reply With Quote
Old 09-13-2017, 01:53 AM   #12
Yakuzi
Touring Car Champion
Yakuzi's Avatar
Drives: intoxicated
K04 or BT is one helluva "light mod"
PM me nudez thx
Yakuzi is offline   Reply With Quote
Old 09-13-2017, 07:17 AM   #13
BlueE30
BlueE30's Avatar
Drives: 10' TR GTI 6M and an E30 325 Turbo
+2.
Only addition is what others are saying - lower it a bit. I have Koni coils, I'm only lowered a bit but really like the drastic increase in performance. If I was on a budget or spent my budget on the aforementioned performance parts, get a pair of sport springs with a mild drop, that will help quite a bit.
2010 TR GTI APR Stage 1 Fully Loaded, APR Carbonio, R8 coils, Rotiform 19's, Koni Coilovers, CTS subframe reinforcement kit, CTS Billet Torque Arm Insert, CTS rear subframe bushing kit, LED Golf R Tail Lights, Xenon Headlights, VCDS changes (DRL's, windows, gauge sweep, etc) and timing chain tensioner updated!
1987 BMW E30 325 Turbo - Too extensive to list.
BlueE30 is offline   Reply With Quote
Old 09-13-2017, 08:29 AM   #14
lilonespaz
Formula 2 Driver
lilonespaz's Avatar
heres a stickied thread titled "Want to modify your GTI? Start Here"
http://www.golfmk6.com/forums/showthread.php?t=36928
lilonespaz is online now   Reply With Quote
