Old 10-21-2012, 03:21 PM   #1
808bahn
Touring Car Champion
Drives: 2012 DSG Autobahn GTI
P3 Vent Gauge Auto-Dimming wire
Hey guys,
For those who have installed the P3 gauge, where did you tap the green wire to for the Auto-Dimming function to work? I searched and read that you can do it on Pin#10 of the light switch, but how do you connect it to that? Do you just splice it to the Pin#10 wire? Are there any other place you can connect it to? TIA.
808bahn is offline   Reply With Quote
Old 10-21-2012, 06:03 PM   #2
Modshack
Formula 3000 Champion
Modshack's Avatar
Drives: '13 Beetle TDi Conv., '14 C7 Chebby
Originally Posted by 808bahn View Post
Hey guys,
Looks like Pin 10 is the one per the AWE instructions:
For Dimmer Knob Controlled Gauge Backlighting:
Switched 12V: Red gauge wire to the Black/Purple headlight
switch wire at position 4.
Dimmer Control: Green gauge wire to gray headlight switch
wire at position 10
Constant 12V: White gauge wire to the Red/White headlight
switch wire at position 8.
Ground: Black gauge wire to the Brown headlight switch wire
PDF here: http://www.awe-tuning.com/media/pdf/...boostgauge.pdf
I'd use the Posilock connectors as supplied with this set-up. Easy to use, compact, no stripping or hassles.. Get em here: http://www.easternbeaver.com/Main/El...posi-lock.html
Modshack is offline   Reply With Quote
Old 10-21-2012, 06:11 PM   #3
808bahn
Thanks Steve! Much appreciated.
Old 10-21-2012, 06:16 PM   #4
Modshack
Modshack's Avatar
No problem!
I've always been one to cut, spice and solder, but I have to say, the posilocks are trick...Especially on the fine wires used in the switch. Good luck!...
Old 10-21-2012, 06:22 PM   #5
SkullV
Banned
Drives: 2010 Tiguan SE 4Motion
Yep, just used the gray wire for the dimmer on my Tiguan too. Seems like VW kept with the color scheme.
SkullV is offline   Reply With Quote
Old 10-21-2012, 07:17 PM   #6
808bahn
Great! Thanks.
Old 09-13-2017, 07:26 AM   #7
Jonnyboi
Drives: 2010 vw gti
Bringing this back from the dead. I tapped my green wire into the grey #10 wire coming from my headlight switch but it still doesn't dim when I turn on my Headlights. Is there a config setting or something I have to enable for it to work?
Jonnyboi is offline   Reply With Quote
Old 09-13-2017, 09:43 AM   #8
drval85
Drives:
Yep. I think there's a setting you need to change to "auto." Check the p3 manual.
drval85 is offline   Reply With Quote
