Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Volkswagen GTI / Golf Topics > Mk6 vs......
Old 04-04-2017, 09:20 AM   #15
zef
Rally Car Newbie
Drives: 2013 GTI
I guess I'm lucky haha, I used the scissor jack for 3-4 months before I eventually needed more height (I of course lowered it onto a jackstand after I raised it).
Old 04-04-2017, 10:07 AM   #16
riceburner
FIA GT Champion
Drives: 2012 GTI DSG / K04
not that i prefer using it, but i actually think it's an okay jack? lol. It's pretty easy and effortless to use and puts the car up enough to change a wheel or something if needed. I don't believe it's going to just collapse under it's own pressure or something, I really can't see VW putting themselves at such a liabiity.
The only thing i can see happening is the car moving and making it topple over on a slope or something, since it doesn't have too much outward or side to side support/legs.
As with any jack, I prefer not to get under a car unless I have stands.
buildie buildie.. http://www.golfmk6.com/forums/showthread.php?t=110051
riceburner is offline   Reply With Quote
Old 04-04-2017, 10:11 AM   #17
zef
Rally Car Newbie
Drives: 2013 GTI
Yeah I definitely would not want to shake the car at all. There was one time it did wobble a little because I forgot to put the ebrake on. That was a little scary... but assuming flat solid surface I never had an issue
Old 04-04-2017, 11:16 AM   #18
TimS
Rally Car Champion
Drives: '12 Golf R
Yeah, exactly. It's designed to be compact and to get a wheel off the ground on the side of the road. It's perfectly competent at that.
Never ever ever put any part of you under a car that's only supported by a jack. Ever.
Old 04-04-2017, 11:18 AM   #19
riceburner
FIA GT Champion
i dont. maybe i didn't word that correct. haha
Old 04-16-2017, 08:31 AM   #20
elcroato
Drives: 2010 VW GTI, 2000 Skoda Octavia1.8T
I wouldn't agree. Mine failed when the threaded portion began to give out, causing the car to fall. I was lucky to have another widow maker close by in my old mk4. I then supported the car before it touched down and I finished swapping wheels. Too be fair I had used it more than a few times, so the metal was probably fatigued.
2010 VW GTI: APR STG II, APR Downpipe, Wavetrac LSD, 130000KM.
elcroato is offline   Reply With Quote
Old 09-16-2017, 08:00 PM   #21
SnailPower
SnailPower's Avatar
Drives: 2014 GTI Wolfs CSG 4DR MT
Originally Posted by whitewolf33 View Post
I thought this was going to be scariest car jack(ing) in history. Im so disappointed. Not that I want to see that happen to you or anyone on here but its interesting to see or read about
Rofl same.
With that said, I've never used it since buying the car, however heard plenty of stories.
I also agree that VW wouldn't provide a jack that is that bad. If you are getting hurt using it, it's moreso because you are using it for NOT what it's designed for. I'm sure they had only tire changes in mind and at that, it shouldn't be all that dangerous since you don't need to get under the car.
Now if you are using that jack and getting under the car, I think that's more at your own risk and the reason it's known as the widowmaker, lol.
Internal : APR Stage 2+ tune - Soundaktor Delete - Diesel Geek Sigma 6 Short Shifter - R8 Coils - ECS Dogbone Mount Insert - GFB DV+ - NGP Type I Coilovers - KMD Tuning Front Stress Bar - WhiteLine Endlinks - IE CAI - IE K04 - EuroJet DP - Magna Flow Exhaust
External : H8 Pure Yellow Fog Bulbs - 20% All Around Tints - ECS JOM Euro Style Badgeless Grille
SnailPower is offline   Reply With Quote
Old 09-16-2017, 08:02 PM   #22
SnailPower
SnailPower's Avatar
Oh man, I had to share this pic also, hilarious
