The Tire Rack
Old 07-21-2017, 02:23 PM   #3991
Vroomtt
Drives: 2013 GTI Driver's Edition
I should also note I'm currently running 10mm spacers up front and 15mm in the rears.
Don't want any rubbing, hence going with dsg springs for my dsg gti. Not too worries about rake, just want a planted lower setup
Vroomtt is offline   Reply With Quote
Old 08-04-2017, 12:27 AM   #3992
ACHILLES R32
Touring Car Newbie
ACHILLES R32's Avatar
Drives: 2013 GTI Drivers Ed
Still have not installed my dg springs, but just ordered some koni yellows. Might as well do it right the first time , even though im at 28k with stock shocks.
Total will be $476 after koni rebate.
https://www.tunersports.com/koni-spo...x-2_p6016.html
Thanks snobrdrdan !!
Sent from my Pixel
2013 GTI D.E. DBP DSG
APR Stage 1 - Neuspeed P-Flo Intake - OEM R Tails - Euro Lip - Suntek Carbon 55 Tint - XPEL Headlight/Fog Kit - Hoen Fog Bulbs - Neuspeed Catback - Neuspeed Charge Pipe - Neusped Discharge Pipe - Neuspeed FMIC - GFB DV+ - R8 Coil Packs - VW DG Springs/ Koni Yellows - Unibrace UB
ACHILLES R32 is offline   Reply With Quote
Old 08-04-2017, 12:30 AM   #3993
ACHILLES R32
Touring Car Newbie
Double post
Old 09-04-2017, 05:36 PM   #3994
ACHILLES R32
Touring Car Newbie
so im getting my springs installed next week. wanted your opinions if i should change the curent bumps stops . current ones have 28k miles on them.
list of parts that i have
dg springs and koni yellows
Front Upper Strut Mounts from Audi TTRS Mk2
Front Upper Strut Bearings
6 x Strut Mount Bolts
2 x Strut Mount Nuts
2x Drive Axle Bolt
6x Front lower control arm nuts
2x stabilizer bar connecting link
2x Strut lower bolt
2x Rear lower Control Arm Bolts/nuts
Old 09-04-2017, 06:53 PM   #3995
hbrown0509
FIA GT Newbie
hbrown0509's Avatar
Drives: 2013 VW GTI 4DR DSG
2x Drive Axle Bolt
2x Strut lower bolt
Do the DGs come with new bump stops?
hbrown0509 is offline   Reply With Quote
Old 09-04-2017, 08:43 PM   #3996
ACHILLES R32
Touring Car Newbie
Mine did not
Sent from my Pixel
Old 09-04-2017, 10:16 PM   #3997
hbrown0509
FIA GT Newbie
hbrown0509's Avatar
The Official Driver Gear/VWR Spring Thread
Mine did not
Sent from my Pixel
Not sure if trimming them will be necessary or not? My VWR springs came with shorter bump stops, so maybe they don't drop enough to need trimming. If you're putting all new parts in, you might as well put new bump stops in.
Old 09-04-2017, 11:38 PM   #3998
Aphix
Aphix's Avatar
Drives: 2011 2dr 6MT GTI
mine didn't when I bought a few years back.
APR Stage II v2.0 | RSR clutch | Sigma Six SS | TWM Big Type-R | Unitronic CAI | GFB DV+ | Golf R IC | Unitronic TBE | Neuspeed Pulley / TOP / TBP | Soundaktor Delete | HPA (75A) | SuperPro ALK / LCA / RCA | BILSTEIN PSS10 | 034 Strut / Trans / Motor Mounts | H&R 26mm (S) / 24mm (S) | Tyrolsport Subframe Collar / Brake Stiffening Kit / Stage II Aluminum Hatch Brace | R8 coil packs | NGK PFR7B | Modshack trim | OZ Alleggerita | Hawks HPS 5.0 | Michelin PSS
Aphix is offline   Reply With Quote
Old 09-04-2017, 11:51 PM   #3999
ACHILLES R32
Touring Car Newbie
Will be getting new bump stops just not sure to go with the oem US spec (70mm-133mm) ones or shorter euros specd ones. (55mm-118mm)
I will probably also replace the front endlinks and the rear shock mounts aswell
Just dont know if its really necessary on a car that has 28k miles
Sent from my Pixel
Old 09-05-2017, 03:34 AM   #4000
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Grab the Euro ones, IMO
2017 Passat VR6
2017 Passat R-line
Old 09-05-2017, 02:06 PM   #4001
ACHILLES R32
Touring Car Newbie
Thanks for the quick reply
Sent from my Pixel
Old 09-10-2017, 10:28 PM   #4002
hbrown0509
FIA GT Newbie
hbrown0509's Avatar
So think I'm going to start saving up for some Bilstein B8s to pair with my VWR springs. I think they are just to stiff for the stock dampers. Tired of the squeaking majority of the time and the crash ride. Lesson learned! I even had the shock mount and bearing replaced on one side because I thought it was a bad bearing.
Just making sure the Bilstein sport (B8) pairs better than the B6 (HD)?
Old 09-19-2017, 08:19 PM   #4003
ACHILLES R32
Touring Car Newbie
So i got my dg springs and koni yellow's installed. Went with 1 full turn from soft in the front and 3/4 in the rear. Stopped by the shop, drove the car for a bit definitely firmer but a nice firm. Will pick up the car in the morning. Think it will be a fun drive to work
Only thing the mechanic was not happy with is the negative camber on the front right its at -1.59.
He offered to slot the strut tower but i told him ill wait and put some miles 4-5k and then we will look at the front right tire wear.
He didn't put as much negative camber in the rear to offset the front. So technically its out of vw spec at the moment.
And i don't have a before specs ,he forgot to measure it.
Do you guys think that much negative camber in the front right will be bad? Car drives fine , doesn't pull goes straight .
Pics
Before
After ( Car also needs a wash lol)
And to add to the comparison spotted this MK7 GTI today, i swear the wheel gap is worse than the stock mk6 suspension. But a nice car either way.
