Old 07-09-2017, 07:53 AM   #71
mistaleung
Banned
Drives: Golf GTI MK6
Sub to this. My car got a P2015 code.
mistaleung is offline   Reply With Quote
Old 08-28-2017, 04:56 AM   #72
phatmat88
Drives:
Sub'd to read later....
phatmat88 is offline   Reply With Quote
Old 08-28-2017, 08:57 AM   #73
jysaw
Oval Newbie
Drives: GTI
try the adaptation in VCDS group 142
jysaw is offline   Reply With Quote
Old 08-28-2017, 10:45 AM   #74
FriggenT
Formula 5000 Champion
Then you need a new manifold
FriggenT is offline   Reply With Quote
Old 08-29-2017, 05:48 AM   #75
bmanc42
Drives: gti
When I did this after I put the manifold back on I was leaking gas so had to change the seals. I did not use the tool just put them all on with my fingers. For the white one that go into the head i used a bic pen with the ink cartridge removed as a replacement for the tool the carefully slid them on the injectors. Then used a zip tie around them to squeeze them back to size it was not perfect and I had to use the hole they go into by carefully turning them back and forth before the would go in fully. Also I used silicone spray on all the seals before inserting into head and putting manifold back.
bmanc42 is offline   Reply With Quote
Old 10-03-2017, 04:39 AM   #76
phatmat88
Drives:
Please explain.
Old 10-03-2017, 10:08 AM   #77
FriggenT
*sighs* oh God, I gotta do this very soon, not looking forward to it.
What's everyone's advice for the injector seals? It's like 40.00 for all 4, but do I need to do them? If so, do I need to get the tool to put them on?
Old 10-04-2017, 08:39 AM   #78
fbgmoney
Drives: 2014 CW GTI DSG
I bought the seals and tool from ECS and wound up returning them after not noticing any fuel leaks for a day and half.
fbgmoney is offline   Reply With Quote
Old 10-04-2017, 09:41 AM   #79
FriggenT
How many miles were you at?
Old 10-04-2017, 12:42 PM   #80
fbgmoney
I was at 67K. The seal tool kit fits in a medium USPS flat rate box so the peace of mind costs around $13 and a trip to the post office.
Old 10-04-2017, 01:02 PM   #81
Geryon86
FIA World Rally Car Newbie
Geryon86's Avatar
Drives: MK7 R
Check out my DIY pictures. Used a DIY walnut shell blaster pieced together from Harbor Freight and Home Depot. If anybody local needs to borrow an injector tool, walnut blaster tool, hit me up!
Before:
After:
16' LB R | DSG | APR Stage II HT |
11' SB GTI
|DSG|APR v3.1|CTS K04|
Geryon86 is offline   Reply With Quote
Old 10-04-2017, 01:39 PM   #82
FriggenT
Before:
After:
Looks great man
Old 10-04-2017, 05:02 PM   #83
Dans GTI
Drives: 2010 MK6
After doing my carbon cleaning, i put the injector seals on without the tool.
But after the cleaning i've developed a random misfire, its only happened 3 times now in the past 7 months. But still. Could be fuel injector related, i have no idea.
For the peace of mind i recommend you do it the right way.
2010 MK6 GTI 6MT: APR Stage 2.4 High Output : eBay special downpipe : IE Intake : R8 Coils : BKR7EIX : DWS06 : 034 Dog Bone Mount : 034 Dog Bone Insert : StopTech Brake Pads : SPM CatBack : Sachs ZF Clutch : Diesel Geek Short Shifter : GFB DV + : Clutch Stop :
Dans GTI is offline   Reply With Quote
Old 10-04-2017, 06:37 PM   #84
GTIguy30
Drives: 2011 CW 4Dr GTI - APR Stg I
I had 3 injectors that came out with the manifold. I tried to replace the seals without the tool and had at least 1 fuel leak if not 2. I am guessing I would've had better luck not trying to replace the seals.
So I had to do the whole process all over again the next weekend. If you are going to replace the seals, I recommend getting the tool. My brother will need the cleaning done on his CC coming up and I told him he can borrow the tool for $40, so I will make some of my money back.
Also, I did not use media, and didn't get nearly as clean as the images above. I did get large chunks out and the stems are very clean, but the backside of the valves still has probably a 1/16" or so thick layer of crusted stuff on it. Even with that, it was a noticeable, I think, improvement.
GTIguy30 is offline   Reply With Quote
