Old 10-05-2017, 08:57 PM   #1
notovicrious
notovicrious's Avatar
Drives: 2011 GTi 2.0T
Another Front End Sound :/
Ok so forgive me if this ends up being something thatís been covered a million times but itís new for me and Iím not sure what it is yet so idk where to post.
Iím experiencing a cranking noise under the driver seat/center console only after a complete stop and lightly pressing the gas into first. After I start to roll and it ďcranksĒ I donít hear it until the next complete stop. Not every stop either. I donít think temperature matters and is not exhaust related. If I had to guess it sounds like subframe area. Hoping itís not DSG related. Iíll cry. Iíve yet to check tightness on necessary subframe hardware so thatís tbt. The car just hit 60k. Stage 2 COBB.
Iíll try and get a video soon but itís very unpredictable and unless it gets worse I wonít know when to record.
Any help would be greatly appreciated!
Old 10-05-2017, 11:07 PM   #2
FriggenT
Formula 5000 Champion
I see a lot of that, there's a subframe fix that was posted a long time ago using better or just different bolts.
On a side note I hear a clicking sound when I'm driving at low speeds, it almost sounds like a brake pad or something clacking together.
FriggenT is online now   Reply With Quote
Old 10-06-2017, 06:22 AM   #3
notovicrious
Yes Iím going to do the Tyrol update for good measure. Iím almost hearing a popping sound also so Iím leaning towards subframe even more so. Itís not a metal in metal and Iíve changed the end links already their not rubbing. Itís a weird old wooden ship creaking/cranking big wooden door opening sound lol.
Old 10-06-2017, 06:24 AM   #4
notovicrious
Get a vid as soon as you can bro.
Old 10-06-2017, 07:13 AM   #5
Carlosfandango
FIA World Rally Car Newbie
Carlosfandango's Avatar
Drives: 2010 MK6 GTI 6MT CSG
Are you turning when you hear it or is it in a straight line? It is common for the subframe to creak and knock at slow speeds if the bolts are not torqued properly, New bolts and some shims will fix it!
Iíve also had a weird creaking in the past that turned out to be the CV joint gaiter/boot squeaking, as I turned the boot would rub against its self making the noise! Silicone spray stopped it,
Old 10-06-2017, 07:17 AM   #6
Carlosfandango
The CV boot squeaked more so/only when the roads were wet!
Old 10-06-2017, 11:46 AM   #7
notovicrious
Thanks for the help, I seem to only hear this noise when going straight and not during driving or turning. Only from a complete stop until what seems to be the point where the engine and trans shift back due to momentum? Itís hard to say but I feel a little bit of it in the pedal and under my seat. Never while turning. Starting to hear little popping noises while driving though. Like Iím going over small bumps when Iím not.
Old 10-06-2017, 11:56 AM   #8
Carlosfandango
Engine mounts maybe??
Old 10-06-2017, 07:52 PM   #9
notovicrious
They look fine and arenít loose, the noise is coming from the middle like maybe the dogbone or something. Iíll have to check that tomorrow, maybe just by a new pendulum mount with the Tyrol kit for the subframe. It isnít trans related could it be?
Old 10-06-2017, 08:47 PM   #10
Carlosfandango
I was including the dogbone mount when I said engine mounts even though itís technically the trans mount!
Old 10-06-2017, 09:16 PM   #11
notovicrious
Facts.
Old 10-07-2017, 02:43 AM   #12
Carlosfandango
Facts.
Some would disagree! The mount under the coolant tank, the lower pendulum mount and mount under the battery are all engine mounts really, some refer to the one under the battery as the trans mount! Either way all three do the same job.
Old 10-07-2017, 07:45 AM   #13
notovicrious
Well the front mounts do the most. The one under the battery is for the trans and the other for the engine specifically. The pendulum mounts subframe to trans. I get all that. Iím just worried itís internal now. Iím going under there later to have a look and check tightness.
Old 10-09-2017, 11:53 PM   #14
ebuuz
ebuuz's Avatar
Drives: Mk6 GTI
I get a loud clunk from driver side front under hard braking and sometimes hard acceleration. I can feel it through the pedal so its brake/subframe related somehow.. I do have the tyrolsport deadset and 034 mounts so it might be the last mount (hockey puck one) or maybe something else loose.
Does yours happen with hard braking?
2012 CW 6 speed. F23T on APR k04 v3.1, APR Carbonio, CTS turboback, Clutchnet 6 puck disc, 034 Street Density motor and transmission mounts, Hawk HPS 5.0, Motul RBF600, Newsouth boost gauge, DieselGeek SS
Dyno vid of my car
ebuuz is offline   Reply With Quote
