SOLD
I had this set powdercoated by a local shop who didn't mask them properly when sandblasting and coating the calipers. I bought a replacement set in the mean-time while they sent them to a local brembo rebuilder who cleaned the bores and rebuilt them with brand new seals and refurbished pistons and pressure tested them.
They've not been installed since and include a used set of brake pads from the original boxster (which I would probably replace) and all hardware including an extra set of pistons and the original seals and brake wear sensors as well as a set of brembo stickers. To mount these you'll need a set of brake lines with the flare for these calipers and the creations motorsports brackets. These fit the OEM rotors, so for ~$500 you can have a great brake set up with better feel.
More information here for those unfamiliar with the setup: http://www.golfmk6.com/forums/showthread.php?t=36589
