The Tire Rack
Old 06-20-2015, 06:03 PM   #15
HYDE16
Formula 2 Driver
HYDE16's Avatar
Drives: 2011 MK6
Ha, love that color. The XTA camber plates are really nice dude.
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
Old 06-21-2015, 08:23 PM   #16
stevenchkim
stevenchkim's Avatar
Drives: '10 CW 6M QT Hatch
Ryan, I went and picked up the GC camber plates and the next question is how much camber are you running front/rear and why?
CTS K04+APR v3.1|Neuspeed P-Flo|UR TBE|Neuspeed FMIC|DG Sigma6|TWM M1 Brnz|Eibach F&R Sways|GC Camber Plates|034 Eng&Trns mnts 50-d|EurosportACC Strut&Xbraces|UR under brace|ECS front end skid plate|KW V2|MFactory Helical LSD|SB S3 Endr|RB4045 BBK|Advan RS 17x8 ET47|HK V12 255/40/17|P3 Gauge|Depo Tails&5k HIDs|stud conversion 14x1.5 to 12x1.5+Raicer lug nutz|Raicer LEDs
<--Flickr
stevenchkim is offline   Reply With Quote
Old 06-21-2015, 08:26 PM   #17
HYDE16
Formula 2 Driver
HYDE16's Avatar
Drives: 2011 MK6
My car is setup for straight line acceleration and high speed stability. Front camber is at -1 to account for the positive camber change upon acceleration and front end lift, the goal was to net a neutral camber for max grip.
YouTube: HYDE16
Old 11-16-2017, 05:27 PM   #18
jay745
Mod Flanders
jay745's Avatar
About to buy a set of vorschlag camber plates to pair with eubach mulipro r2 coilovers. Can't find anyone running those camber plates on this platform, found a few threads with worthless replies so I guess I'm guinea pigging!
Old 11-18-2017, 08:54 AM   #19
mg_90
Rally Car Newbie
mg_90's Avatar
Drives: 11 GTI
Been running the IE plates paired to Bilstein B16 coils for 15 months and the bearing on the driver side already failed; which seems to be a common failure for IEs plates.
For sure the car has seen lots of track but they were supposed to be designed to be able to cope with that, I am higly dissappointed.
If someone requires more info just ask
Instagram: @mk6gtimike
mg_90 is offline   Reply With Quote
Old 11-20-2017, 04:21 PM   #20
zef
Rally Car Newbie
Drives: 2013 GTI
I was going to go with IE camber plates and decided to go with super pro ball joints. Got up to -2.2 at full adjustment. Settled for -1.8. Got the adjustment I was looking for without killing ride quality.
Old 11-20-2017, 10:09 PM   #21
jay745
Mod Flanders
jay745's Avatar
I'm not a fan of those due to the nylon nuts they use. Way too much heat in that area of track use for nylon
Old 11-21-2017, 03:04 AM   #22
Clownish
Clownish's Avatar
Drives: GTI
Have you had experiences or seen them fail before?
Clownish is offline   Reply With Quote
Old 11-21-2017, 07:13 AM   #23
jay745
Mod Flanders
jay745's Avatar
seen them fail unfortunately
Old 12-15-2017, 11:47 PM   #24
the1bill
Drives:
So, I was thinking about this earlier since I use the SuperPro ball joints on my car. I only autocross my CC, so heat isn't the same kind of problem for me as it is for you, but perhaps nylock nuts aren't needed. I know that the stock ball joints use pressed bolts and single use nuts. The SuperPro ball joints come with grade 12.9 bolts and nylock nuts (grade 10, I think). I think they went nylock because grade 12.9 is hard to keep locked, with 90% max torque being specified to ensure that the nut doesn't back off. Instead of going to 90%, the nylon does a good enough job at a temperature range that's fine for most people.
Since the SuperPro uses nuts and bolts, I think it might make more sense to source replacement bolts at the same grade as OEM. That way, OEM single use nuts can be used, heat isn't going to be a problem, and you'd still get camber adjustability.
Is there anything about this that sounds unsafe?
the1bill is offline   Reply With Quote
