Old 12-30-2017, 05:53 PM   #1
iAmJakeToo
Newbie
Drives: MK6 GTI Driver's Edition
Will the aFe Si Pro (TDI Stage 2) Intake work on the GTI?
Hey everyone, I'm new to the forum so my apologies if this has been answered as I have not found an answer searching through the archives. I was looking at "stealthy" airbox mods that I can do to my GTI and this intake came to my attention.
It's aFe's Stage 2 Si Pro Intake for the TDI engines but it bolts up to the bottom of the stock airbox. Super stealthy and after looking at the instructions for installing the intake, the airbox on TDI engines look exactly the same as the TSI airboxes in the GTI with only one minor change being the brass nipple on TDI engines.
That got me thinking about using this intake on my GTI and plugging up the hole where the brass nipple is, but I don't know if anyone has tried this before or has thought of this as an alternative to the intakes marketed to our cars.
Any help is appreciated and thank you in advance!
iAmJakeToo is offline   Reply With Quote
Old 12-30-2017, 05:55 PM   #2
smanierre
Drives: MK6 GTI 6-SPD Shadow Blue
If it bolts up to the air box correctly and also to the stock intake tube I would think it's fine, it's before the maf so unless it's really screwing up the airflow I don't think it should cause any problems.
smanierre is offline   Reply With Quote
Old 12-31-2017, 06:13 AM   #3
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Yes, it should work...you just need to plug that hole where the brass nipple is (in the pic above) on the aFe intake
2017 Passat VR6
2017 Passat R-line
Old 12-31-2017, 12:35 PM   #4
iAmJakeToo
Newbie
Thanks guys! I'm currently saving up some money so this will definitely be my first experiment on my GTI. An update may take awhile, thanks again for the input.
Old 12-31-2017, 09:21 PM   #5
BudgetPhoenix
FIA World Rally Car Newbie
Drives: 09 GLI
One issue might be the is the MAF housing is different on the TDI, and might be a different distance away from the airbox so you might need a coupler thats a different length and diameter, possible one that necks down if the TDI maf is smaller. There's plenty of 2.0T intakes that are covered as well if that's what you're looking for
Tags
intake, tsi
