Old 12-22-2017, 12:06 PM   #1
GroceryGTIer
Drives: 2013 black Wolfsburg
Forge catch can (older style) questions
My wife got me a CC and gave it to me early. It's the older style forge cc with the Africa plate, and the elbow on top of the plate. That parts great. However, forge has a new design that uses the OEM pcv, so now I'm wondering if that is something I should swap out, or if my current one should be ok. I have just seen a few issues where people consumed a lot of oil with the old style.
Any info or personal experience?
GroceryGTIer is offline   Reply With Quote
Old 12-23-2017, 09:00 PM   #2
mk6'12gti
Drives: 2012 4dr Black Gti
Never was a fan of forges original design because silicone hoses aren't the best idea plus there is better designed african plates out there.
| Apr Ko4 v3.2 | Apr stage 2 Dsg | Do88 Ic | IE intake | Circuitwerks turboback | Ecs street shield | R8 coils | S3 style top | Spulen throttle pipe | BC coils | Uni dv relocate | 034 street density mounts | 034 pendulum mount | Hpa 75A puck | P3 Gauge | GFB Dv+ | Apr catch can | Osram headlights |
mk6'12gti is offline   Reply With Quote
Old 12-24-2017, 05:36 AM   #3
11gti718
Oval Champion
Drives: 2011 GTI
I’m currently running a forge catch can setup you described. Not sure if it matters but i’ve been using it from stock to ko4. Never had any issues with it consuming large amount of oil. One thing I can say is that it does work. The stuff that comes out of the can is crazy.
11gti718 is offline   Reply With Quote
Old 12-24-2017, 07:20 PM   #4
GroceryGTIer
I appreciate the comments, anything that anyone else can chime in on would be great. Hyde? Any info? I know you had one a long time ago.
Old 01-02-2018, 06:15 PM   #5
HYDE16
Formula 2 Driver
HYDE16's Avatar
Drives: 2011 MK6
I like ECS's design the best in terms of retaining the factory PCV and factory breather tube assembly to the turbo inlet. Their can baffle is a much better design as it will not become blocked when blowby in the can freezes. The only thing I do not like and agree with is the plug which blocks off the front of the PCV (ECS or any other CC), I still run the vacuum line from the front of the PCV to my Audi all-road manifold. The stock PCV is designed to work with vacuum from the intake manifold. Plugging that with any aftermarket catch can block off will elevate crankcase pressures at idle or off throttle if using the stock PCV.
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
Old 01-03-2018, 12:43 AM   #6
GroceryGTIer
Did you have the older style with the single hose and silicone hoses on your forge setup? The pics don't work anymore
Old 01-03-2018, 05:41 AM   #7
mk6'12gti
if I remember correctly you complained alot about the hose length on the intake side not being long enough on the ecs catch. The ecs catch can is alright I had one but it fit like shit on my uni intake. I prefer the apr catch can which is what I have now works great with my IE intake. Apr's is better designed then ecs's can in my opinion.
Old 01-03-2018, 08:13 AM   #8
HYDE16
Formula 2 Driver
HYDE16's Avatar
Drives: 2011 MK6
Yes I did, as they designed the hose length for an OE turbo inlet pipe diameter (stock intake). Like I explained in that thread, the hose is too short for any aftermarket intake pipe, the hose is too short to wrap around the intake completely. I built my own custom Aeroquip hoses to properly route everything.
The APR kit is nice, but they block off the front port in the PCV plate (to the intake manifold), removing the vacuum source needed to correctly operate the stock PCV in an idle or off throttle state. I've seen countless APR CC cars report smoke out the tailpipe, even a big turbo user with my same turbo kit. Elevated crankcase pressures is not good.
YouTube: HYDE16
Old 01-05-2018, 12:31 AM   #9
mk6'12gti
Hmm I haven't had the white smoke come out of my tail pipes with aprs catch can but I did have that problem with ecs's can.
Old 01-05-2018, 12:51 AM   #10
tkelly0727
Oval Champion
Drives: 2010 mk6 gti DSG
Thank you hyde, i had no idea that it wasnít good to cap off the vacuum source thatís needed, which is why i installed the stock vacuum hose from the PCV to the intake manifold. Oddly enough reason why i got a catch can was because I thought my PCV was falling, bought the car at 78k and now at 103k. No idea if the PCV was every replaced. I was also experiencing rpm dropping to 550, So I replaced it with a new one and installed a catch can and it seamed to got better. But after i installed the vacuum hose back on it looks like it cured the problem *knock on wood*
tkelly0727 is online now   Reply With Quote
