The Tire Rack
Old 01-06-2018, 03:11 PM   #29
Ronnie_B
Touring Car Newbie
Drives: 2013 GTI 4DR Wolfsburg 6MT
Originally Posted by zef View Post
I have the superpro ball joints and had my alignment checked 3 times in the last 6 months and they have not moved at all.
After I installed the tyrol deadset collar kit I had .5 more camber on one side. Decided not to go camber plates due to nvh/harshness. These were a great compromise. These have seen track time as well and no issues either.
Thanks for the feedback! I'll probably go with these and just frequently check alignment with my camber gauge.
/// 2013 Wolfsburg GTI, APR Stage 1 v2.4 93 tune, RSR Clutch, iABED RMS, Carbonio Stage 1 Intake, Diesel Geek short shifter, NewSouth Boost Gauge, SuperPro ALK, Stoptech 309 Pads, Motul RBF600 Fluid, Yokohama ad08r's on OZ 17" Omnia (Track), Michelin Pilot Sport A/S 3 on Serrons(Street)
Ronnie_B is offline   Reply With Quote
Old 01-07-2018, 12:39 AM   #30
Short Bus
FIA GT Newbie
Drives: '10 GTI
Originally Posted by Ronnie_B View Post
Just to clarify, spec is a range of numbers, not a singular number. US Camber Spec is -.5 +/- .5, so a setting of -.9 has the potential of taking away camber from the opposite side. In other words, a setting of -.9 left side / -.4 right side doesn't necessarily mean something is bent, it means that the camber needs to be equalized side to side. (Even though both sides are technically within spec) It's unrealistic to expect -.9 camber on both sides with stock suspension. -.9 is at the far maximum end of the spec range, not "bang on". Make sense?
BTW, all this discussion and I still haven't had anyone chime in about the original question regarding experiences with SuperPro ball joints.
I don't know where you got that number, but I'm pretty sure you're off by half. I also would not accept as much as -.5 off as "fine" any more than I would accept Subaru's claim that a quart of oil consumed every 1k is normal.
To make sure I wasn't crazy I just looked at a half a dozen alignment sheets posted by GTI owners on this subject. The sum of both sides on a healthy car should be roughly -2.0. Add or subtract a tenth or two for worn bushings or key parts like the ball joints, strut tops, or rear position control arm bushing housings being pressed the wrong way against the bolts that secure them in place.
I don't know exactly what your alignment numbers are, maybe it's fine, or maybe you're trying to use expensive aftermarket parts to band-aid a problem. All I'm saying is that if it's off by .5 or more you might want to have a close look. The stock spindles are cast, really weak, and easily bent. Also, that rear position control arm bushing is really sad, even brand new.
Short Bus is offline   Reply With Quote
Old 01-07-2018, 01:51 AM   #31
Ronnie_B
Touring Car Newbie
If you search these forums you'll see a front factory camber spec range of -.5 +/- .5. You'll also find most alignment sheets show a range of -.2 to -1.2.
I never said or implied that .5 difference l/r was "fine". I stated that it indicated that the subframe needed to be adjusted in order to equalize camber.
As for the comment about expensive aftermarket fixes, it's either we shift the subframe or find another way to adjust camber (hence the reason for the use of either camber plates or adjustable balljoints). At any rate, it sounds like you've decided to go a different route than the subject of this thread, and it may warrant your own thread to keep this one on topic. Best of luck!
