Old 01-14-2018, 09:04 PM   #1
Bill1975
Oval Champion
Bill1975's Avatar
Drives: 2013 GTI - Carbon Steel Gray - 6MT
Schwaben Power Bleeder Leaking During Brake Flush
I replaced the transmission fluid and attempted bleeding the brakes in my 2013 6mt GTI today. For the brake flush, I purchased the Schwaben Power Bleeder from ECS, which is basically a copy of the Motive, gets good reviews, and is less expensive.
The problem was I had difficulty attaching the adapter to the reservoir. Despite multiple attempts, I barely got the pressure above 5psi before brake fluid started leaking. Even with the old fluid siphoned out, there was still a leak.
Am I doing something wrong, or should I call ECS about a return? Also, since the reservoir was emptied and refilled, I have a lot of new fluid in there anyway. Should I still try and bleed them, or call it good enough for the next two years?
Sent from my HTC One M9 using Tapatalk
Bill1975 is offline   Reply With Quote
Old 01-14-2018, 09:08 PM   #2
Squashdaddy
FIA GT Champion
Squashdaddy's Avatar
Drives: 6MT 2011 GTI
I have the same one and had the same problem. I had to put Teflon tape on the threads of the reservoir to get a proper seal. One would think that the rubber gasket would be sufficient, but it isn't. A bit of a crummy design if you ask me.
APR Stage 2 ECU - APR Carbonio Stage 1+2 - 42 Draft Designs Catted/Resonated Downpipe - Neuspeed Charge Pipe and Turbo Outlet Pipe - GFB DV+ - Fluidampr Crank Pully - HS Tuning RSR clutch -H&R 24mm rear swaybar - Unibrace UB - HPA Red Puck -Neuspeed Rse12 Hyperblack
Squashdaddy is offline   Reply With Quote
Old 01-14-2018, 09:29 PM   #3
Bill1975
Oval Champion
Bill1975's Avatar
I can try that, but I'd rather just return it if that's the only option.
Old 01-15-2018, 09:58 AM   #4
Tony48
Rally Car Champion
Tony48's Avatar
Drives: 2011 GTI
Had the same issue with that bleeder on my car. Oddly enough it held pressure fine on my dad's MK7 which has the same brake fluid reservoir thread size/pitch.
| 2011 GTI, 6speed, 4dr | Build Thread| Timing Chain Replacement Tips | DIY RSR Clutch & RMS Replacement Tips|
Old 01-15-2018, 11:17 AM   #5
jay745
Mod Flanders
jay745's Avatar
same problem using a euro motiv power bleeder. I think they are all just a crappy design.
Old 01-15-2018, 11:24 AM   #6
MKVInnie
Drives: 2010 CSG GTI 6spd
Wow the irony, this thread started yesterday? I was doing this job last night and ran into the same issue. Got the O-ring mentioned in this video: https://www.youtube.com/watch?v=Yfz9RlvKO0c but am still getting the leak this morning. Gonna try the teflon tape. I should be at work right now, instead I'm dealing with expensive brake fluid spilling all over my transmission and garage floor. Rage.
MKVInnie is offline   Reply With Quote
Old 01-15-2018, 12:13 PM   #7
Bill1975
Oval Champion
Bill1975's Avatar
Saw that video last night. I'll try picking up some o rings. I'm not going to be able to re so the brake job for a while though. I did suction all the old fluid out of the reservoir, so most of the new fluid went in anyway. Not a true "flush" but it's better than nothing for now.
Old 01-15-2018, 12:38 PM   #8
MKVInnie
That's good. As long as there are no air bubbles in the system you should be alright. I got the teflon tape with the o-ring and its sealed now. Probably can get away with just the tape, wrapping it around the reservoir threads 2-3 times.
