Will give it a try. I usually get Shell gas, and the V-Power tends to be upwards of .12-.15 cents more a litre which would equate to $7 a tank and at a tank a week would be sub $400 a year.
research "top tier fuels"
while some people (ignorants) claim that Top Tier Fuels are an addvertisement gimmik, i have done some testing and found out, that on south florida, to the very least, Chevron and Shell are WAY better than the competition.
how to test it?vag com.
log:
-engine temp
-timing pull per cylinder
-afr (commanded and actual)
-torque
test method: do 2 tanks of each fuel grade from the same gas station from the same brand (dont refill until the light comes up for better "cleaner" results)
so:
2 tanks on shell 87,
2 more on shell 89
2 more on shell 93
or go simple:
2 on shell 87
2 on shell 93 and you will see the difference of 93 vs 87.
then feel free to do the same for any other brand and fuel oct to see the difference.
i'm using shell, as it has shown to be the best one and the more consistant one. I recommend testing the top tier to any other, and evaluate the differences.
lastly: i dont/cant do this tests anymore because my car isnt stock, so the results will be biased to 93 based on my Ecu's programming.
