Old 06-08-2012, 08:43 PM   #15
U-20T
Drives: BT GTI4Motion
Originally Posted by mdhollis View Post
Hey JR why isn't that turbo kit on eurojet's website? Is that a new product?
Its actually an old product called the ej400 and was made for the FSI. I used some of the parts from the kit and some of my own stuff to fit it all together.
A few items can be bought upon special request but its no where near a complete kit.
Old 06-08-2012, 09:59 PM   #16
trd420
trd420's Avatar
Drives: 2015 S3 Prestige+Performance Pack
Sweet can't wait to go BT
Now 2015 Audi S3 Prestige + Performance package, DTUK & K&N drop in. Running E-85 blend
Had 2011 MK6 GTI Unitronic Stage 2+ (K04)
Had 1989 MK2 GTI VR-6 Swap
trd420 is offline   Reply With Quote
Old 06-08-2012, 11:29 PM   #17
mdhollis
mdhollis's Avatar
Drives: S3
Looks bad ass. I love your water meth setup........
mdhollis is offline   Reply With Quote
Old 06-15-2012, 06:41 AM   #18
U-20T
Another aquamist update -
Last night I finally had some time to do some work. The ECU is now wired in and the system is 100% electrically. The gauge/system now turns on and does read the injectors (one of them if you really want to be technical). Failsafe also works since I don't have any meth running through it cuts the boost without any issue.
BT is addicting, the low boost under failsafe is so slow. Although its still faster than an R20 at only 10psi.
Old 06-15-2012, 08:10 AM   #19
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
"Like" Button Pressed
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 06-15-2012, 09:53 AM   #20
GTIwannagofast
GTIwannagofast's Avatar
Drives: 2010 VW GTI
STAGE
GTIwannagofast is offline   Reply With Quote
Old 06-15-2012, 06:15 PM   #21
U-20T
Thanks guys, Just posted the wiring info for the HFS-4
Old 06-15-2012, 07:38 PM   #22
mdhollis
mdhollis's Avatar
Drives: S3
Can you post a pic of your downpipe when you get a chance? I know you had to customize it because of the turbo size........I'm going KO4 so the EuroJet downpipe will be fine for me but I'm just curious. I think I'm gonna have to get me an aquamist setup bro.....
Old 06-16-2012, 10:41 AM   #23
U-20T
Aquamist seems to be the best but it is complicated compared to standard systems and is more expensive. Howerton Engineering sells it and they have just about every fitting you would ever need.
I am not taking a picture of the DP because its a hold over at the moment. Right now its a regular DP with the flange cut off and a vband welded on. I will be adjusting the the factory sizes by an inch in the future to get that perfect fit.
Old 06-16-2012, 05:47 PM   #24
steelcurtain
Drives: '12 Audi TT-RS
Do you think those pin-outs are the same for an mkv tsi? I want this kit bad.
'09 GTI TSI - 11.53@121.18
steelcurtain is offline   Reply With Quote
Old 06-16-2012, 05:53 PM   #25
U-20T
I will look it up, what year is yours?, your boost may be on pin 3. Every diagram I had had boost as pin 3 on the t60 connector.
My pin 3 was empty so I had to trace by color and a multimeter.
Old 06-16-2012, 09:38 PM   #26
mdhollis
mdhollis's Avatar
Drives: S3
You get what you pay for..... This system is so worth it.
Old 06-17-2012, 06:47 AM   #27
U-20T
Old 06-17-2012, 08:06 AM   #28
steelcurtain
Thanks buddy. My car is a MY 2009 MKV TSI with a 2008.5 build date.
