Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Regional Forums > NY / NJ / CT / PA
Old 04-01-2012, 10:15 AM   #1
jball12
Rally Car Champion
jball12's Avatar
Drives: 2011 TR GTI 4D 6MT Autobahn
Waterfest 18 Autocross School
Registration opens today and I'm all signed up for the 8am session. It's my first auto-x experience, so I'm pumped! Anyone else doing the auto-x school on 7/21?
APR Stage II / AWE TBE / DG Sigma 6 SS / BSH True Seal Intake / Eibach Sportline Springs / Eibach Pro Dampers / Eibach Front and Rear Sways
jball12 is offline   Reply With Quote
Old 04-01-2012, 11:08 AM   #2
alexgc
Touring Car Champion
alexgc's Avatar
Drives: 09 GTI K04, 86 Scirocco 16V
just signed up.
Cars: 2009 GTI (AWE K04 turbo kit, and too many more mods to even count ), 1986 Scirocco 16V
2012 SCCA South Jersey Region SMF class champion
alexgc is offline   Reply With Quote
Old 04-01-2012, 11:15 AM   #3
jball12
Rally Car Champion
jball12's Avatar
Nice, we should try to get a nice mk6 representation there
Old 04-01-2012, 11:27 AM   #4
alexgc
alexgc's Avatar
I'll ask the Mk6 people I know to see if they'll be able to make it. really looking forward to the instruction and driving tips/tricks from those who have more experience at this. Definitely going to take a step forward from last year's auto-x season.
Old 04-02-2012, 01:11 PM   #5
Gberg2119
FIA GT Newbie
Gberg2119's Avatar
Drives: 2017 Golf R
Didn't know I had to register so soon. I'll sign up when I get home
Sent from my Incredible using Tapatalk
GIAC Stage 2 | Modshack VTDA | SPM DP | Magnaflow CBE | Eibach 26mm/23mm Swaybars | UNIbrace UB | S3 Shift Lever | GFB DV+ | LED Tails | 18" Enkei Raijins
My Build Thread!
Gberg2119 is offline   Reply With Quote
Old 07-23-2012, 10:21 AM   #6
jball12
Rally Car Champion
jball12's Avatar
This was a great event, plenty of seat time and the instructors were pretty decent too. There were about 13 drivers in the morning session, most were GTIs (5-6 MK6), but we also had a nice GTR there as well. One of the instructors had a fully prepped 2008 M3 that was loud and fast.
As a first timer, the whole experience was quite eye opening for me. It was a ton of fun and I'm hooked. This morning I signed up for an SCCA membership in the Philly region and I hope to catch an event towards the end of the season here.
The GTI performed pretty well. It was the first time that I had driven it that hard, and I can see that with a couple small improvements (mostly to me as a driver), it can be a very capable auto-xer.
I learned that I need to improve the following:
1. Driver
2. Driver
3. Driver
4. Brakes
5. Tires
Old 07-26-2012, 12:31 AM   #7
Pooley
Touring Car Newbie
Drives: 2011 CW GTI Autobahn
Autox is so much fun. I used to Autox an 89 CRX and a 2000 Civic Si back in the late 90's to early 2000's and gained a lot of hands-on experience in car control and the limits of each car. I ran both SCCA and NASA events at Giants Stadium, Camden Waterfront, Nazareth Raceway infield, a mall lot in Wilkes-Barre, and even an old deserted go-kart track in Carlisle that was like a mini road course, barely wider than the width of a car. Where else can you drive your car at 10/10ths legally for so little money without worrying about jail time? BIG fun.
I was very competitive in my vehicle class with my Si with very limited modification, but I stopped racing when I got my '00 Audi A6 2.7T in 2004. It was too heavy and just not the right car for such duty. Then in 09 I got a Volvo XC90 V-8, another car not meant for this. This March I finally got a car worth bringing to an Autox, an '11 GTI. Hopefully I'll get the time to get back in the cones in the future.
Some random thoughts-
-Slow in, fast out is the best way through a curve, but its hard to get that in your head when the clock is ticking. That takes practice since the initial thought is charge the turn and brake way too much and slide the front tires.
-Look at the course and imagine a smooth route and plan things out, give up speed in a slow area if it means a fast exit and gains in a higher speed area of the course. -Smoothness is key, avoid unsettling the car with jerky movements.
-The handbrake is a friend and can be used to rotate a FWD car when needed.
-A lot of times the fastest guys aren't squealing their tires as much as the slowest guys, they know their cars strengths and are keeping their car in balance.
-Try running a gear higher through some turns to change the attitude of the car, many times it results in a faster time even if it feels slower.
-Tires make a huge difference, I was given a worn set of 140 tread wear tires and they stuck so hard I couldn't stay in my seat. They were glued to the track.
-Talk to a lot of competitors, even if they drive what looks like a beater they may have the same car as you at home and bring it to other events and could have good info. -Get an air storage tank (basically like an air compressor without the pump, just a tank you fill with a compressor) that can be used to raise tire pressures as needed.
-Tire pressure front to back can totally change the way a car handles. Stiff (high psi) back tires will allow the rear to turn faster, and softer (lower psi) front tires allow more grip. On cars with more sidewall to the tire we used to use white shoe polish and mark the sidewall in 3-4 spots. If the polish was worn off you add air to that tire, if its all there (the shoe polish marks) bleed some air out. Its a good way to see if the tire is getting used to its fullest. Not sure if the super low profile tires of a modern GTI would benefit much from that.
After a day of pushing yourself so hard you'll end up driving a bit slower on the streets and you'll start to pay more attention to little details as to how the car handles and feels, in preparation for the next event. What you learn will last a long time, its been 9 years since my last event and I still mentally take notes as to how the car responds for max performance in case the situation arises.
Have fun!
Pooley is offline   Reply With Quote
Old 07-26-2012, 08:52 AM   #8
jball12
Rally Car Champion
jball12's Avatar
Great advice, thanks man
