I received my RCD330 187B NoName-version two days ago and installed it in my Mk6 2009-model Golf. The device has the following specs:
HW: 534
SW: 5314
BT: C180
CarPlay: 210.81
No problems so far. We only have DAB+ here in Norway, so FM/AM is of no use for me. Everything else is working fine without any bugs.
Should I upgrade to newer software, or are they too buggy still? I don't have Android and therefore have no need for AA.
Any bugs streaming music via Bluetooth and receiving / making calls?
Only bug/problem I encountered was when I connect to CarPlay after having connected the phone via bluetooth. I have to turn of the Bluetooth on my phone. If not, the phone is not sure whether to play via Bluetooth or CarPlay it seems. The radio terminates the bluetooth connection when connecting via CarPlay, and I therefore think that this may well be a phone problem, rather than the RCD330.
Will keep testing later today. Did you have any specific problems regarding streaming music via bluetooth and receiving/making calls, hence the quote?
I'm having a similar issue. When plugged into CarPlay, my calls don't play through the speakers. This is happening even though I've yet to connect to the bluetooth in the unit.
As long as I turn off bluetooth on my phone before i connect to CarPlay via USB, everything works for me.
Perhaps it's "either USB or Bluetooth" by design? Does carplay on other car brands support Bluetooth concurrent?
Here's an update on my recent install as promised. I have successfully soldered in a rear USB output, and AUX out. I have routed the USB to an iPhone dock in the armrest.
My requirements for the dock were:
Must be able to operate single handed (slide in style)
Be flexible to fit different size phones, and cases
Be flat backed so it could be stuck to the side of the space inside the armrest.
Here's some pics:...
My 2017 Tiguan (with MIB/CarPlay) doesn't have a problem with it. Call work via Bluetooth when not plugged in & via CarPlay when plugged in. No need to turn off BT.
So does anyone know why it doesn't display the embeded album art on mp3s. I know for a fact my mp3s have them. I threw a bunch on an SD. Still just shows the box with the music note in it.
My 187B Desay is the same. If I have music playing via BT, and then plug the USB in it will just stop BT music and open CarPlay. Works perfect
Be a firmware thing, nobody has been able to get album art or radio station art to work.
