hi guys i have a 2010/11 golf mk6 1.4 petrol automatic
i was driving the car it seemed to have lost power (gone into neutral) and i adjusted the gear to reselect Drive, it gained power again
after this instance the car would not either go into reverse or drive, it would slip in and out of this mode when starting the car or whilst driving (which is obviously dangerous)
i have had RAC to have a look and they came back with the following analysis
at the moment it is at a garage who is saying he 'thinks' the ecu has gone but will need to look at it further to investigate and it would be around £500-600 pound mark
can anyone suggest any advise what i should do ? or what the problem could be
do i need to take it to a transmission/gear box specialist?
thank you
RAC DIAGNOSTIC SYSTEM
System Type: GEARBOX ELECTRONICS
Name: GEARBOX ELECTRONICS
DTC: P17BF,Hydraulic pump Play protection
DTC: P0841,Transmission Fluid Pressure Sensor/Switch A Circuit Range/Performance DTC: P189C,Reduced function because of pressure drop. DTC: P1895,Reduced function because of pressure drop. cust advised veh was loosing power and now wont drive ptrl carried out tests and suspect internal fault in gbox
thank you
