Dear All,
First of all, let me introduce myself. I am Hassan and I just bought a used MK6 GTI 2010, 2.0 DSG that has been driven almost 115,000 KM.
Unfortunately, It needs hell amount of work ! Things like, Stabiliser Bar, Ignition Coils, Oil Separator, Vacuum Pump & Gasket, Turbo clips, Lower Arm bushes, Coolant Secondary Pump,Charcoal Container, Timing chain tensioner, intake manifold, Crank Shaft Rear Flange.
The mechanic just told me that some Plastic parts of the manifold are broken and have fallen down in the engine and God knows where else ! The mechanic told me that I need to replace the engine ! There is no other way.
Now I had different plans for my GTI. After discovering those issues, then I better fix it first then start the mods.
My question, What do you guys think ? Will it fit if I insert TT-RS Engine OR RS3 Engine in my Gti ? I am talking about 2.5 TFSI.Would I need a bigger intercooler in this case or better cooling system ?
Also In case I will choose to replace the current engine with another GTI 2.0 TSI engine, Will there be any issue to put a newer engine from 2013 since my GTI is 2010?
Thank you all, I would appreciate any feedback from you guys as I am panicking at the moment !
I am just embarking into the Motor and mods industry
