Old 07-05-2017, 10:05 PM   #1
markus037
Drives: 2011 GTI 4dr DSG
so my cpo warranty expires in 10 days..
should i be worried? lol. i had the updated timing chain tensioner installed, changed the dsg fluid, had the water pump recall done. not sure what else im missing.
Old 07-05-2017, 10:07 PM   #2
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
Sounds like the intake manifold will implode on itself in about 11 days.
Old 07-06-2017, 12:40 AM   #3
drval85
Check for oil leaks. Just replaced the rear main seal on mine, also had a valve cover leak.
Old 07-06-2017, 01:07 AM   #4
Mk6 Steve
Drives: 2013 Black GTI coupe DSG
Begin to shit yourself! Jk keep up with the maintenance and you should be ok
APR V3.1, APR K04, Carbonio Stg 1+2 w/ AEM dry-flo filter, APR RSC TBE, Do88 Ic, 034 Catch Can Kit (summer), OEM pcv "AH" (winter) AWE S3 top, Neuspeed charge pipe, Rev D w/ DV+, R8 coils w/ NGK 2668, 034 motor/trans mounts, HPA 75A, TyrolSport subframe and brake stiffening kit, Unibrace UB, F+R Centric w/ StopTech Strt pads, USP SS brake lines, Depo dark cherry tails, ECS Blind Spot Mirrors, Enkei 18x8 black M52 w/ Conti DWS, Soundaktor delete, VCDS Hex-Can, P3 gauge
Mk6 Steve is offline   Reply With Quote
Old 07-06-2017, 09:40 AM   #5
damagi123
damagi123's Avatar
Drives: 2012 GTI DSG
go big turbo
Old 07-06-2017, 09:40 AM   #6
JSwag420
JSwag420's Avatar
Drives: '12 CSG DSG GTI
I brought mine in on the last week as well and they found a rear main seal oil leak. Apparently, it would have cost over 1k to fix.
Btw if you've fallen victim to the sagging headliner disease, mention that and they'll replace it under warranty.
Old 07-06-2017, 09:46 AM   #7
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
Most people don't get it taken care of under warranty. My dealer gave me the number to a guy who would give me a discount.
Old 07-06-2017, 08:14 PM   #8
markus037
probably going to do the pcv system next oil change. car is at 54k i hear they like to go around 60k
