Old 07-21-2017, 01:15 PM   #1
MelowGTI
Sunroof Draining into Front Passenger Footwell
Sunroof is draining into front passenger footwell. I observed as a poured a cup of water down from the sunroof, I could literally see the stream of water emptying into my passenger side footwell. I was told that the drain is clogged but it seems like its draining in the wrong place? Living in south florida where it rains everyday I need this fixed
Any possible solutions? Much appreciated. Thanks
F23T/Revo Stage 3/ CTS Turbo Intake System, ARM MOTORSPORTS FMIC, SPM Track Turbo back w/ 200 cell cat / SPM Lowering Springs/Cooper Zeon RS3-A / VMR 710s / LED Dark Cherry Tails/ New South Boost Guage/ R8 Coilpacks / NGK Iridium Spark Plugs/ Turbo Smart MBC.
MelowGTI is offline   Reply With Quote
Old 07-21-2017, 03:28 PM   #2
Corradoluvher
Drives: 2013 vw gti
Wow i cant believe our mk6s do this as well. I had the same issue with my B5 passat. I took it to a VW specialist they basically cleaned the drains from the sunroof. They exited on the driver door. It looks like a plastic nipple just squeeze it and clean it. Try to be careful ass if u use a pressure house u can damage the drain. I havent checked our cars but thats what he did to my B5. Do it quick before it eats up your wiring harness as it did mine.
Old 07-21-2017, 06:45 PM   #3
JSwag420
JSwag420's Avatar
Drives: '12 CSG DSG GTI
What exactly are those drains even for? When I wash my car, my footwell is full of soap and water. Even from the littlest rain storm, it's filled with water. I've never seen any other car do this before. It comes from the sunroof?
Old 07-21-2017, 09:31 PM   #4
drval85
I think there's a drain at each corner of the sun roof. The fronts can be cleaned from the top down, the rears from the rear wheel wells up. Use fishing line to poke around.
Old 07-21-2017, 10:27 PM   #5
ithrashmotors
ithrashmotors's Avatar
Drives: Mk6 gti
Had this similar issue. Remove the passenger a pillar trim and then leak test the sunroof. The drain hose runs behind that a pillar and is connected by a connection tube right by the dash and they tend to knock loose. It's a bitch to reach with your hands. If the drain hose is connected and the water is leaking from the sunroof still then most likely the sunroof seam where it mates to the car is leaking. This happened to me and I applied silicone sealant from Home Depot on the seam. When this area is leaking it will roll down the a pillar and collect on the passenger foot well which seems like that drain hose since they both will dump water in the same spot. Your drain hose nipples are located in the fender wells for both front and rear.
APR stage 1//Carbonio intake//R8 coilpacks//GFB DV+
ithrashmotors is offline   Reply With Quote
Old 07-23-2017, 10:30 AM   #6
Carlosfandango
Carlosfandango's Avatar
Drives: 2010 MK6 GTI 6MT CSG
I used a long length of brush cutter nylon cord, it worked a treat!!
Old 08-16-2017, 01:28 AM   #7
BS2H
BS2H's Avatar
Drives: 2011 UG GTI BS2H
I have this same problem. I poured water into the passenger sunroof drain and it's pouring right down into the passenger footwell - the drain connection does not go through the firewall into the fender.
What are our options? I don't want to remove any trim. I guess I can seal the sunroof drain hole with sealant or a rubber stop so that the water drains to the other 3 holes.
I saw an issue with another guy with a 2011 mk6 gti and both his front drains were "too short" from factory and did not reach the firewall into the fender. May be a common issue?
BS2H is offline   Reply With Quote
Old 08-21-2017, 01:34 PM   #8
ithrashmotors
Drives: Mk6 gti
You need to remove the a pillar trim to really see what's going on. The water could be leaking from the sunroof seam and rolling down the a pillar onto the floor. Or the tube connection behind the a pillar can be knocked loose like mine was along with the leaky seam. When the connection is loose the water won't drain into your fender area.
Old 08-21-2017, 01:35 PM   #9
ithrashmotors
Drives: Mk6 gti
It's a bitch to put the a pillar hook back in its slot when your re installing but I took as large pair of forceps from work from our instrument room and it did the trick. Just have patience and don't mark up your dash.
