Old 01-15-2018, 04:16 PM   #1
GtiDom25
Drives: Mk6 GTI, Stage 2. BillyBoat �
Question Clutch Questions
Hey guys what's up, I have a question about a clutch. So I have a 2012 gti with a 3inch full turbo back catless billyboat exhaust, neuspeed air intake, forge spacer, and a custom stage 2 tune. I've had this tune for a few months now and it's wearing down my stock clutch obviously, so when the weather warms up I'll need a new clutch. My real question though is can I get away with buying a new clutch disk and keep the stock flywheel and pressure plate? Im asking because I've heard this a few times. If I can save an extra $700 id like to. So is it ok to just buy and use a new stage 2 clutch disk without the the rest? Any insight helps, thanks!
GtiDom25 is offline   Reply With Quote
Old 01-15-2018, 04:30 PM   #2
Tony48
Tony48's Avatar
How many miles on the clutch? How many have been tuned? Are you hard on the clutch? Will you be installing the clutch yourself?
Some have gotten away with upgrading the disk only to the South bend stage 3 drop in disk at low mileage. If you have a lot of miles or a lot of wear on your clutch you'll want to replace the whole clutch. Look into the DIY RSR clutch kit as a budget, full-clutch, alternative for holding up to K04 power levels. I think you have lots of research ahead of you
Old 01-15-2018, 04:36 PM   #3
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
I'd replace the pressure plate for sure. It seems like that's the reason the clutches begin to slip in the first place.
It wouldn't be a bad idea to replace the flywheel too, but if you have pretty low mileage you could get away with reusing the old one. If you've been driving around with a slipping clutch you might want to replace it. You can't resurface a dual mass flywheel.
Old 01-15-2018, 05:08 PM   #4
GtiDom25
The car has just under 50,000 miles, I've had the tune for probably 2,000 miles maybe a bit more. I don't drive it hard because I want my clutch to last as long as i can, but it does slip if I do a pull.
Old 01-15-2018, 06:00 PM   #5
PhthaloType
PhthaloType's Avatar
Also, the OEM pressure plate has been revised since the original one in your 2012. Some folks (myself included) have had the old one suddenly fail, so now's your chance to replace it with a better quality part and not have to worry about it.
2013 GTI Autobahn
4-Door
6-Speed Manual Candy White Titan Black
Bone stock!
PhthaloType is offline   Reply With Quote
Old 01-15-2018, 07:08 PM   #6
Slowgti08
Slowgti08's Avatar
Drives: 2008 VW GTI
If it was me Ill replace everything . Dropping the trans ( labor ) once is a lot having to do it twice for something such as the pressure plate or flywheel having issues is absurd. Do it right the first time. Save your self money in the future
Old 01-15-2018, 07:17 PM   #7
GtiDom25
I totally agree with that as well, one of my thoughts was just to do it all while I'm under there. I'll be doing the work myself so it would be annoying to have to go back under a second time.
Old 01-16-2018, 10:59 AM   #8
Tony48
Tony48's Avatar
I recently did a DIY RSR clutch install (IMO a good clutch for your scenario if you want to retain OEM NVH) and did a write up with part numbers, links, tips, and pics in my build thread. Follow that link and scroll down to the bottom. It should help you out. Let me know if you have any questions since the job is still fresh in my mind.
Old 01-16-2018, 12:19 PM   #9
ferrariF60
ferrariF60's Avatar
Drives: 2010 TR 2DR GTI
i have to agree on the RSR clutch; i have the same set up on my car (albeit i bought the kit directly from HS tuning b4 people started to piece together their own) and i must say i absolutely love it; 20K miles later still grabs like the first time and best of all its got the same STOCK pedal feel as a stock car
2010 TR GTI 6MT: APR Stage 1 ECU | APR carbonio | HS Tuning RSR Clutch | Red DB Mount Insert | Neuspeed Charge and Discharge Pipes | Neuspeed Cat Back | GFB DV+ | H&R Sport Springs | S3 Shifter & 42DD Aluminum Bushings | OEM Golf R LED Tails | Golf R Side Skirts | OEM Front Lip | H&R 12-15mm spacers | PIAA Ion Yellow Fogs | Aspherical Mirrors |
ferrariF60 is offline   Reply With Quote
Old 01-16-2018, 06:11 PM   #10
drval85
My RSR's engagement point is much lower than OEM. Only complaint. Otherwise I 100% recommend.
Old 01-16-2018, 11:04 PM   #11
Tony48
Tony48's Avatar
I read this everywhere but mine is the same as OEM. Not sure what caused mine to be different.
