DRL Question on MK5 Jetta 2011 Euro spec
DeonB_S_Africa
Hi There,
I have been searching all the VW forums for the last couple of days and cannot get any info on how to switch on my car's DRL via fog lights.
It doesn't even work with low beams..
I have been able to successfully enable cornering lights via fog lights. On my VAG-COM some tick boxes are not visible, but via help from the forum, i have changed all the relevant bits in byte 11, 15, and even byte 18.
I have changed the region to NAR, ROW, but then only the chimes are different.
On my previous MK5 Jetta (2009) i have done the DRL via fogs, but it doesn't work on the 2011 model? Any ideas why?
My car has factory fitted front fogs, halogen headlights, LED tails wit one rear fog and one backup light. Euro headlight switch with Off/Auto/Park/ON/Front fogs/Rear fogs.
When I try to enable DRL via separate lights, I get the bulb out message on the MFD.
All the trigger wires are connected at the headlight switch
Please help
Thanks,
Deon
