I have to agree. My lights have been spot on throughout the interior. I bought the entire kit (including the rear license plate lights).
People joke about never losing me in the dark until I take off like a madman on the freeways. They also joke they don't need headlights running because my LEDs are brighter. LOL
Only one array has an issue - my driver side footwell seems to flicker every so often (red color array for those wondering). I can't pinpoint it, and it isn't all the time, but it was the first array I installed, and is the only one to have this issue. It flickers at idle as well as during driving.
Otherwise, when at a stoplight and I turn a light on... wham, thanks I'm happily blind now LOL.
The flickering is a known issue. I just installed a kit and the passenger footwell + one of the domes flickered for a while. It stopped doing it on its own.
If it keeps doing it, you can fix it /w VAGCOM.
http://deautokey.com/led-diy-faq-customer-reviews
Yes, the cold diagnostics of the car which sends high volts of electricity MIGHT cause the LEDs to act in this way, we always suggest shutting this off through VCDs to avoid any issues that these high volts might cause.
Most of the time it doesn't effect the LEDs though.
On the 2012, in my case, the Cold Diagnostics are not available.
It should be available for a few areas of your cars, license plate/footwells.
Also driving with your footwell LEDs off will prolong the life of these LEDs, when you accelerate, high volts are sent to the LEDs, and if they are on, it could burn out the resistors.
Thank you
Not in the 09-Cent Elect section, in my case. I followed the link from your website that directed me to VWVortex thread. I have the rear LED back up lights, License plate LED, as well as, the LED turn signal lights. They flicker upon starting the car, except for the License Plate.
I love these lights! Only one slight problem? Passenger side footwell light went out, and the overhead lights are flickering? Not sure why this started happening.
I'm expecting to receive my LED kit later this week. I don't think that my Canadian 12 Golf TDI highline has foot well lights. Does this mean that I don't have a bulb or don't have an actual socket wired in?
Update:
I checked the car out and haven't found a socket where i think there should be one. Does anyone know if i can retrofit the plug for foot well lighting?
