Federal 595-RSR update
ROK
Finally had our first auto-x this weekend and the tires did great! I cant say they are better than the RS-3 but certainly no worse. My car is stock except for APR sway bars front and rear set to the softest setting on both. I ran them at 45 psi rear and 50 psi front cold. It was 87 deg partly sunny. After each run the fronts showed a spread of around 10 degrees across the tread and the rears around 5. It seems as if they roll over a little less than the RS-3 did. Try them out you probably will like them.
valj
Best budget tires money can buy - RS3 and 595 RS-RS
Both perform as well as AD08
I have been running the new revision of RS3 with the uprated threadwear (200)
They now wear out less and are just as sticky as the previous version
ROK
I should also say that they are very easy to drive. If you are driving the corner right they will very smoothly loose traction as slip angles increase. I checked out the results from the event and was pretty impressed at the competition I came in faster than. It's gonna take more than just these tires though to beat the guy with the lightened CRX with full suspension mods and r-comps! Damn those things!
