A full turbo setup well built is about 7000$CAD and more from what I have seen.
Just to give you an idea.
- 5 Bosch 550cc injector : 325$CAD + tax + shipping approx.
- Bosch 040 fuel pump : 260$CAD + tax + shipping, you might find a Walbro pump cheaper
- PrecisionTurbo 5858 : 1400$CAD journal bearing, 2200$CAD ball bearing + tax + shipping
- Exhaust manidold / turbo manifold : 800$CAD+
- Precision 46mm Vband Wastegate : 500$CAD
- Diverter Valve (I would not get a BOV except if you are maf-less), a Tial QR is about 350$CAD
- An intercooler, VibrantPerformance sold them near 400$ CAD
- Custom downpipe works approx 300$ depending of the job
- An IE intake manifold, you could keep the stock one, but I don't think the plastic one would support the boosty very well plus you wouldn't get the best performance from your turbo setup without the intake manifold : 1100$CAD
- An UnitedMotorsport Fuel Injector tune, near 750$CAD, maybe less
- Oil lines, fittings, piping for the intake : price may vary...
Pretty much what you need for basic setup, then you will have to upgrade your clutch, otherwise it will slip and slip... Performance clutch kit is near 1200$CAD
If you don't install it by yourself, you will have to pay for labor time, just the clutch is near 5-6 hours. You will always have to use 91 octane gas. You might have to change some other stuff like fuel filter. I would also get an AFR gauge and a boost gauge, near 250-300$CAD, a wideband will cost more...
Keep in mind the 5speed differential can be weak... And you might need to replace it in an unexpected moment ^^
It's not cheap but if you have the money and want to keep your car for a long time without caring of the resale value, then go for it, it's a nice project and you will have a reliable turbo car with decent power
If you are planning to put an Haldex AWD, it's near 4000$ CAD using R32 parts.
