I know GIAC uses RS4 injectors.
Sent from my HTC One using Tapatalk 2
+1
rs4 injectors are worst than standard golf R injectors. the golf r motor is identical to s3 motor afaik.
and afaik, s3 injectors > rs4 injectors.
which part? RS4 has a worst spray pattern than S3. this was described by that other guy which wrote an essay on this matter.
if you have a point to prove, say it. Don't have to orientate the question in such a way.
You're the forum sponsor, i won't disagree with what you have to say if you know more information than just a small fry me does.
I'm just stating what i know.
hence AFAIK :w00t:
If APR is the know-it-all, then they decided to modify S3 injectors over RS4 injectors. There must be a reason why right? Take the best and make it better
Can't possibly argue that maybe S3 injector is cheaper than RS4 hence why they used S3 and modify it, because RS4 injectors are SO much cheaper than S3 injectors. :yikes:
