Old 05-16-2013, 01:21 AM   #1
lasesking
Drives: cw.gold.custom
k04 upgrade stock tune
Hello. Im looking into getting the k04 upgrade. And I was wondering if I can buy the turbo amd all that and instalk it myself to save money and drive maybe an hour at most to get the correct tune! Or should I get stage 2 + first then do the turbo? I cant find much about this. And if it is possible will I be in limp mode or destory anything? !!
Thankzz
lasesking is offline   Reply With Quote
Old 05-16-2013, 01:56 AM   #2
apa11393
Formula 3000 Driver
Drives: GTX30 '12 GTI, '96 Miata
I'm guessing you drive a gti
I drove my car for about 2 weeks with stage 2 software after I got my k04 installed. No problems at all, just don't floor it and you'll be fine.
apa11393 is offline   Reply With Quote
Old 05-16-2013, 08:32 AM   #3
lilfleck
Moderator
Drives: '11 GTI Autobahn, DSG
Hm... I'd call APR and ask.
lilfleck is offline   Reply With Quote
Old 05-16-2013, 11:30 AM   #4
lasesking
Called apr..no answer
Called unitronic answer right away! They said you can drive with k04 on bone stock tune. Just dont go under boost
Guess I know who im going withh
Old 05-16-2013, 12:51 PM   #5
GTI_likeurmom
GolfMK6 Elite
GTI_likeurmom's Avatar
Drives: Veyron 16.4
you can drive a ko4 without the tune, just take it easy with the throttle. allot of us have done the install ourselves and then get the tune when we get around to it.
Originally Posted by GOBbluth View Post
I cut the tether off. When I get to the pump, I remove the cap and chuck it into the nearest bush, patch of trees, or some sort of wet lands. I pump gas. Then I spend anywhere from 5 to 165 minutes retrieving the cap. I screw it back on and drive away. I'm not letting it dangle against the paint and I don't know any better way.
GTI_likeurmom is offline   Reply With Quote
Old 05-16-2013, 01:56 PM   #6
corrado917
Formula 3000 Driver
corrado917's Avatar
Drives: GTI CSG
Don't do Stage II,save for the turbo instead.There specials coming due car shows.
Check this out for example:http://www.uspmotorsports.com/CTS-TS...ware-Only.html
Have you ask G.I.A.C ?
A buch of goodies APRís K04 kit, NGK 8 plugs , Unitronic Intake, Eurojet DP, Magnaflow catback, APRís TCU tune, 034 Dogbone Mount Insert, S3 intercooler, Forge catch can, Modshack trim, AWE tuning IC hoses, Neuspeed K04 TOP & TDP, H&R Cup kit, Golf Rís skirts & side mirrors, Euro LED tails, GTD grill, H&R sways, Stern bar, Enkei RPF1 & some other stuff..Build
corrado917 is offline   Reply With Quote
