Old 12-12-2017, 12:40 PM   #6665
brobst
brobst's Avatar
Drives: CSG mk6 6MT
One was mk6 r. Other was mk7 r
Old 12-12-2017, 12:43 PM   #6666
GroceryGTIer
Drives: 2013 black Wolfsburg
Right, but I had initially said a 2015 R iirc... my point is is38, AWD, all other obvious stuff.
Old 12-12-2017, 12:47 PM   #6667
Cadubya
DUBYA
Cadubya's Avatar
Drives: 2011 K04 GTI 4DR 6MT
Originally Posted by GroceryGTIer View Post
I realize this, but where are you getting 28k from? Charles just said 17,8 was about the cheapest. So 19k maybe
MK7. Charles was quoting a MK6.
CLICK HERE FOR MY BUILD
Old 12-12-2017, 01:11 PM   #6668
GroceryGTIer
Ok, there was some confusion there then. I was thinking 19 for the 7R ma bye but I haven't looked. VW doesn't seem to have a great resale value
Old 12-12-2017, 03:08 PM   #6669
zef
Where are you guys getting these crazy resale prices from? Salvage yards? Auction?
Clean MK7s are still north of 20. MK7R's are well above 30, even for used ones (and there aren't many used ones available). Hell, even some '14 fully loaded MK6's are still fetching 17-18k. VW's have insanely good resale value.
Old 12-12-2017, 03:20 PM   #6670
GroceryGTIer
30s for a 2015??
Old 12-12-2017, 04:46 PM   #6671
zef
30s for a 2015??
For a MK7R, yes. I have not seen any under 30k. They haven't even been coming off lease yet. It's a $45,000 car new, VW don't lose even close to that much resale value that quickly. It's not a BMW/Mercedes.
That's why so many people are still buying new GTI's/R's...because they want such a premium for the used ones youre just better off buying a new one.
Old 12-12-2017, 05:14 PM   #6672
jettaglis
jettaglis's Avatar
There are used mk7 r's for 25k or so. North of 70,000 miles. I watched one sell from Copart (flood car- with no warning lights, ran and drove with 31k miles) for 16k.
Uni stage 3....gt3076
Instagram: vsc_tuning
Old 12-12-2017, 08:24 PM   #6673
brobst
brobst's Avatar
Drives: CSG mk6 6MT
I would never buy a flood car. Couldn't give it away to me
Old 12-12-2017, 08:44 PM   #6674
GroceryGTIer
If it was a freshwater GTI?
Old 12-12-2017, 11:36 PM   #6675
LAGP
Drives: Audi A3
Here is a sample from a log I did on my compound turbo setup to check for fueling issues, I think they look ok but could anyone with experience tell me their opinion. Boost was 25 psi on 92 octane fuel + water meth injection.
Sent from my LG-M700 using Tapatalk
LAGP is offline   Reply With Quote
Old 12-12-2017, 11:46 PM   #6676
LAGP
Drives: Audi A3
Originally Posted by Charles@NGP View Post
I hear you, my suggestion for the LSD was mostly because it's a lot more cost effective for the average person to have us install to their car and get significantly more out of the power that they're making. The best possible setup IMHO is to have both a front LSD and AWD. I have a Peloquins high torque LSD installed on my CC and I love that thing. When coupled with the solid SuperPro 26mm rear sway bar I have on it now and the extra 5" of wheelbase that you get with the CC, you can really start to control the rotation of the rear of the car.
The only downside right now is that I can't do any burnouts unless its slick outside due to all the traction (I really need to get around to slapping a big turbo on it or going with my dumbass 2.5L swap idea). I also wish someone would finally step up and get a proper rear diff made for Gen 4 Haldex! I know I've seen the threads on getting them made, but so far no one has actually come through.
Mfactofy has an lsd for the haldex unit, here's the link: http://store.teammfactory.com/a3-tt-...ical-lsd-rear/
Old 12-13-2017, 12:04 AM   #6677
vwgti2.0t
Drives: 2011 CW GTI
Fueling looks good from a quick glance. You're going to need to modify requested boost (not sure what tune you're using, if Eurodyne increase Target Filling) as you're maxing the MAP but the request isn't maxed.
The real question is what does timing look like? Actual advance and correction. And for the logs to be of much value you're going to need far more data points and a one gear log from 2k to the limiter.
Old 12-13-2017, 01:01 AM   #6678
LAGP
Drives: Audi A3
Thanks for the advice, right now I am running Giac K04 file and letting the ecu control everything like usual since 90% of the time it performs like K04, on top of that I am just adding fuel and limiting total boost with the big turbo wastegate. If this doesn't work I will have to go Eurodyne.
addicted to torture, blow up ur volkswagen, breaking your trans 101, failwheeldrive anonymous, fireball lives!, james'partout
