Carlosfandang0
I checked out the multi fuse and this is what I see:
Front:
Back:
Looks like the whole unit is soldered together. I’m gonna look up the part number and see how much a replacement is. Not even sure if the fuses are blown
Presumably there would be some sort of obvious damage if a fuse had blown but that may not be the case? I’ll take a look in ELSAWIN to see if it gives any details, also from searching the web I have read that indeed the alternator could be damaged so you need to check if the battery is receiving a charge when the car is running as one of the first steps if only to rule it out! you won’t know which path to take unless you find the problem first.
