I've never seen/heard this anywhere else so I decided to post it here. Very simple situation, when I'm engine braking I hear this very loud ticking, its barley noticeable in the cab but on the outside must be loud because its most noticeable with the windows down obviously. Now I shouldn't really say engine braking but when it occurs I'm in gear and off the throttle, as soon as I'm out of gear it stops. I've described the noise as a mountain bike chain noise when they make that ticking (I don't ride bikes so I have no idea what causes that noise on a bike) to people and they completely agree that its mainly dead on to that noise. No CEL or anything else while this occurs, car operates just as normal. Now if this is normal (which I suspect its not) then I feel stupid and please point it out if not then go ahead with the assumptions. I've tried recording it but between road noise and general engine noise it was hard to pick up the sound, I might be able to do it from a stand still today.
The second noise is a grinding / knocking noise purely clutch related. It's most noticeable at idle on the first start of the day, I've heard this noise on other youtube videos and main causes are claimed by the thrush bearing. Once I push in the clutch pedal its gone. Its super noticeable from the outside, I haven't tried to record it since I've seen it in videos before, if needed I can link to the videos. I also notice that once the car warms up the noise goes away but its still slightly there no matter if the car is at operating temps or not.
Car has 139800 miles (just hit on my way into work :happyanim: ) a homemade CAI (PO), charge pipes, and a BSH throttle pipe.
