zee
The module you need is 1Z0 035 729 C with its antenna.
Vagcom is not required as it is 100% plug and play, unless you need voice command.
Only coding required to enhance the function is
- to change the steering wheel microphone button from mute to voice command(if required).
You will loose two fuctions
- bluetooth A2DP music streaming. MDI will still work 100%.
- Buttons next to the sunroof.
http://www.golfmk6.com/forums/showpost.php?p=11678&postcount=6
