Fuse Tap for constant power (5 amp)
Cal2000
I need to fuse-tap for constant power (5 amp) on my 2013 GTI.
Any particular fuse that you recommend that I fuse-tap for constant power (not switched)?
Thanks!
pdan
Do you really mean constant power as in always on, or ignition on only?? When I hardwired my radar detector I think I tapped into the sunroof fuse.
Orient Express
There are several fuse positions that do not have a fuse installed, but have power. Get your volt meter out and pick one then use a fuse tap to get the power. Each year of GTI/Golf model has a different fuse layout, so you have to do some hunting.
Cal2000
Thanks! Yes, constant, always-on power. It’s for dashcam with parking mode.
Cal2000
Will do. Thanks much!
Orient Express
Here are some of the slots that I have used:
The reason that there are two fuses on these add-a-circuit taps is that one if the original fuse that was in that position, and the other is the fuse for the new application.
Cal2000
Will I still need tow fuses if I'm tapping into an unused fuse slot?
Cal2000
I'm also installing a dashcam as well, can you let us know which fuse slot you used for always on? Thanks!
Mine is MY13. I checked and found that slots 22 and 33 are alway-on.
You might want to double check as VW changes fuse box config pretty much my to my. Hope it helps!
