Looking for someone on Long Island to do a quick VAGCOM process to recalibrate flappers on the intake manifold. Will come to you and compensate with beer or cash.
http://www.golfmk6.com/forums/showthread.php?t=108678
Intake Manifold Runner
Prerequisites:
## Ignition ON
## Engine OFF
## System voltage at least 11.0 V.
[Select]
[01 - Engine]
[Basic Settings - 04]
Group 142
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
Wait until Field 4 shows "ADP. O.K.".
[Done, Go Back]
[Close Controller, Go Back - 06]
## Switch Ignition OFF for at least 60 seconds.
Notes:
## Timing chain driven engines such as the CCTA, CBFA and CCTA were phased in during model year 2008. Those engines use an entirely different IMRC system which uses engine vacuum in conjunction with a solenoid so Basic Settings 142 must be completed at idle.
## Never run Basic Settings with the IMRC motor linkage disconnected from the intake manifold. It may damage the new part.
Prerequisites:
## Ignition ON
## Engine OFF
[Select]
[01 - Engine]
Group 142
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Notes:
