OrangeSpy
What NGK platinum o iridium spark plugs fit in a 2.5? (links if you could please)
anyone...
Can someone with expertise please charm in; is alignment required if changing subframe bolts?
I got the same setup and while a Vibrant resonator didn't completely eliminate the drone , at about 50 to 65 it is almost silent. Still some drone on high gear slow acceleration and above say 80 or so but that's more a product of running past 3000 rpm I think
sent via carrier potato
Haven't seen this question answered so I'm asking for opinions. My dealer does walnut blasting to clean the valves; cost is approximately $700. My 2012 has 63k and I feel it's about due. The trouble is my water pump is one of the OEM "blessed" ones, i.e. zero issues at 63k. Is it safe and/or even possible to do the valve cleaning without the risk of effing up the water pump? I really don't want to create a water pump failure just because I feel the valves should be cleaned. Car always starts perfectly but I can feel slight hiccups during idle that make me believe it's dirty valves. Coils & plugs are pretty new.
So I noticed today the drivers side center vent is stuck closed, I tried spinning the wheel to open and close it, it doesn't move. Any way to fix this without ripping the dash apart?
Just an fyi - LOTS of us on here experience odd shakes and bobbles at idle yet the tach doesn't fluctuate. I only have 22XXX miles and have been experiencing these for thousands of miles. So it might not be dirty valves, though with that high of mileage it probably couldn't hurt. Just wanted to throw that out their.
does anyone know if the windows come tinted from the factory? I know they are obviously extremely light if they are but I'm curious if they are like 85-90% tinted or just straight up clear glass? I'm going to get my car tinted very soon and I would like to stay at most 35%... I just don't want to put 35% on top of factory tint and end up with 30%...
Not sure...but the shop that tints them will use the correct film to get the % you want. They can gauge the % on site
