jeez
Thank you. Ok so 3rd 4th 5th but you do not go to redline.
When K03 it's 6500 when K04 it's 7000 (APR"s DSG redlines).
Your WGDC never goes below 76% then rises to 98%, cause I'm assuming you're on a K03 with the stock wastegate. So it probably is that the amount of boost (21) is borderline max for your spring, I think. If you are on stock wastegate it's good that it holds 21 till 6k RPM. You're K03 with stock wastegate, right?
My issue happens right around 6k RPM, so it's later than that you provided.
Sent from my HTC 10 using Tapatalk
EDIT:
Sorry just saw you're K04, Tapatalk won't show. Is your tune final and what wastegate are you on?
EDIT:
