DekeTurbo
After the last few days I've finally got most of my audio issues resolved. The last of my issues is a very minor crackle (the sound I'm hearing is almost like the crackle sound you get with a record player every so often). It happens at all volumes and happens intermittently. It's not coming from my sub but rather my 6.5's which are running from a separate 4 channel amp. The ground wire is only about a foot long and its 8AWG and I'm pretty confident that it's location is okay. I don't hear any engine or alternator noise. I also made sure to separate the power cords with the RCA's and the ground for both amps are separated as well.
The only thing I can think of is either
1. The speaker wire is too thin (I used the wire that came with the speakers and I think it's 16awg)
2. something is wrong with the cross over (the speakers came with tweeters that connect directly to them then go to the amp, but the speakers don't have a cross over)
3. it's something to do with the Amp settings (Right now I have it an AP which is allowing all frequencies to pass rather than specifying).
The equipment I have are the Rockford Fosgate Prime 165-S (4) and Rockford Fosgate R300x4 Prime Amp. The output is LP using RCA's.
Any help or suggestions would be greatly appreciated.
Thanks!
-DT
Thanks!
-DT
